Re: The Butler's Desk Build - Workspace
Brian Holcombe
Thanks for your comment William.
It's a bit late at this point, with the cabinet practically together, but I think on *some* future projects I will begin with an overview of the project, a sketch of the design periodically point out which part I'm working on as I go.
For instance, putting together a Nakashima style table doesn't really warrant much overview, but the next cabinet or complicated table that I do certainly will.
As to your comments on the batten, that is correct it functions much like a breadboard end and will ultimately be locked in the center to allow the panel to expand at the outside edges (or biased toward the top). It's similar but different from the bread-board end style fold down desks I've seen historical examples of.
The hinges are firmly located with screws and yes part of the reason for doing this, is as you've observed, the screws are into side grain. The are housed not by the battens (except the small shoulder) but by the bridle joint, which is at least equal to the side grain support it would otherwise receive (not that much).
It has it's positives and negatives, but it did also provide the aesthetic I'm looking for.
The final bit of work to be done on this is to install a friction stay so that the hinges will not be subjected to excessive forces.
