Front Vice Rear Jaw Design ???
DONinSTL
I have a 1-3/4 inch thick Grizzly maple workbench top on which I want to install a Lee Valley quick-release front vice (the York European model). My intentions are to make the rear face 15 inches long X 2-1/4 inches thick X 6-1/2 inches top to bottom, thereby providing approx. 4 inches of usable throat depth above the screw. I want to keep the face of the rear jaw flush with the front edge of the table.
My dilemma is how to design the rear jaw, with strength being my primary concern.
Option 1 – I can simply glue a 4-3/4 H. X 15 L. X 2-1/4 inch thick piece of maple to the bottom edge of the table top. This creates a 33.75 sq. in. horizontal glue joint near the center of the rear jaw work area. Is this a weak spot or is the glue joint actually stronger than the wood?
Option 2 – Remove a 2-1/4 X 15 inch section from the front corner of the table, then glue in a 6-1/2 H. X 15 L. X 2-1/4 inch thick piece of maple. This would allow for a vertical glued joint surface area of only 26.25 sq. in. (not counting the end-grain to end-grain portion), but it eliminates the horizontal glue joint associated with option 1.
Option 1 is certainly easier to construct than option 2, but I’m not sure that should be part of the criteria.
Please feel free to share your experience or suggest any other method of construction you know to be superior.
Thanks, Don
