Shellac Life
Shellac Life
Shellac Life
John McGaw
I know that there have been a lot of questions and postings about this subject but I thought that you might find this interesting. I have been working toward finishing my 7-foot sycamore trestle table and decided to fall back on my old standby finish for such pieces: tung oil, garnet shellac, wax.
Tung oil was easy enough since I didn't have a drop in the shop so I bought some. I checked and found that my supply of garnet shellac flakes was pretty low but decided to go ahead and use it up before buying more. That was when I discovered that by some magic my gallon can of alcohol was now empty while I know that there was at least a quart in there the last time I checked. Then I found under the bench a pint plastic squeeze bottle of old pre-mixed shellac. I do mean old too -- at least ten years since it was mixed. I decided to see what it was like after all that time, expecting the worst, but found that it was still perfectly usable after a brief shake when padded onto a test piece of sanded and oiled sycamore. This suggests that under the right circumstances and in the right container shellac may have an insanely long shelf life despite complaints to the contrary. My thought is that the fact that it was shop-mixed and in a plastic container rather than metal has everything to do with this sample's extended life.
Re: Shellac Life
Re: Shellac Life
walta
I think the way to test your shellac is to put a few drops of shellac on a piece of glass let it dry 24 hours. Scrape the shellac off with a razor blade.
If what you scrap off is a flake that you can blow away your shellac is still good.
If you find a gummy spot in the glass the shellac is dead.
If you get something that sticks to the razor I would not use it.
Walta
Re: Shellac Life
Re: Shellac Life
John McGaw
I knew of that test but didn't bother to perform it for lack of any suitable piece of clean glass in the shop. After your message I decided to go ahead and try the test even though the shellac set up perfectly on a test piece of wood suitably prepped as in the real thing. The ancient shellac passed the flake test with flying colors without even needing to resort to a razor blade -- I could raise a perfect flake with nothing more than a fingernail with no residue left behind. Guess I'll go ahead and use it on the table and hope that I don't run out.
Re: Shellac Life
Re: Shellac Life
I have some garnet flakes that are only a few years old and they no longer dissolve in alcohol.
Re: Shellac Life
Re: Shellac Life
John McGaw
Well, my remaining garnet flakes look OK but since my alcohol has mysteriously disappeared from the metal can I can't check them now. I've started padding shellac on the table top, a long process the way I do it, and am hoping that there is enough in the squeeze bottle to finish it and the trestle components. Guess if I run out I'll discover how my flakes are doing after I buy some fresh alcohol. I use a very light cut for padding so I might be able to squeeze out some from the remaining flakes (assuming that they haven't gone bad).
Re: Shellac Life
I Quit Garnet
due to its shelf life limitation.
Used to have several grades (Pale to Dark Garnet) but found that the less refined stuff went bad just sitting in the closed cabinet.
Now I just buy the Ultra Pale flakes and use TransTint dye concentrate to get the tone I want. Have some flake that's 4+ years old and still just fine.
Re: Shellac Life
Re: I Quit Garnet
John McGaw
I guess that would be a good way to go. Of course I seem to screw up every time I try to mix dyes of any sort. I'm just hoping that my known-good premixed stuff is going to last through this project. At my age there is always the assumption that every project is my last...
Re: Shellac Life
Re: Dye
TransTint liquid is simple to use an additive to shellac for tinting. A little bit on a table knife tip lets you work up your own formula to get the tone you want. Garnet is easy to replicate with two drops of medium brown or 1 drop of dark walnut to a quart, and maybe a touch of Amber. You tint your alcohol first, check the color applied to a scrap, then mix in your flake.
BTW a $10 kitchen chopper-in-a-hopper makes it easy to "powder" your flakes for quick dissolving.
