How to remove chewing gum?????
From a vinyl floor.
I would be unkind of me to say what I thought about the people that rented my house, but they left it with about ten wads of gum thoroughly stomped into the kitchen floor. Some are clearly older and better stomped than others.
Any suggestion on how to remove it? Some sort of plastic scraper that won't harm the vinyl? Solvent? What kind?
Re: How to remove chewing gum?????
Ralph Lipeles
I believe that I used to put ice cubes on the spots and after a while used a piece of wood to knock off the frozen pieces of gum.
Tom Pilsbury (Chicago)
Having spent 21 years as a janitor working in a state university it never ceased to amaze me how chewing gum wound up on the floor. Did it just fall out of their mouths? :\ Or are they just pigs who spit gum on a carpeted floor? Still shaking my head.
Anyway, we had a sort of canned air product that would freeze the gum so we could chip it off with a scraper. Kind of a pain but it worked. You could probably find something similar at a hardware store. If not, try an ice cube. That's what I read in all the "household hints" type of articles in magazines.
John McGaw
Most of the 'canned air' type products sold for dusting computers will spray a liquid when held upside down. The temperature of the spray when it evaporates is probably at least -50F and will freeze most things, skin included, in short order. I used to use it for troubleshooting electronic circuitry suffering heat-related problems as well as for its intended purpose.
Grant in Iowa
Barry,
Almost any kind of lubricant is good to remove gum. Here at work, I use a product called Houdini, which is an aerosol designed to lubricate locks. This works pretty good on carpeting. But you didn't ask about carpeting, did you?...you asked about vinyl flooring.
I would suggest WD-40, PB Blaster, Cooking oil, etc. These items will not likely dissolve the gum, but they do provide a lubricant to keep the gum from "resticking" as you scrape, brush, pick, or otherwise try to remove the gum. I would recommend applying a lubricant of some kind liberally, then scrape the majority off of the floor with something like a plastic spatula. Once you have the majority removed, then use a stiff brush or perhaps the same spatula and go after the rest. Keep the lubricant on the surface during this entire process, reapplying as needed to keep the gum from sticking further.
On carpet, I use the Houdini product, which doesn't seem to leave behind much of an oily residue. I use a small screwdriver or pick to pull the gum out of the carpet, then apply the lubricant, then more picking, and eventually it all comes out. This is on commercial carpeting, which is usually short carpet nap. I have been known to give longer carpeting a haircut.
So lubricant is the key regardless of the surface. You will need to remove the lubricant, so think and plan for that phase before beginning. To remove the lubricant, something like Simple Green or a mild solvent like perhaps alcohol should work well without leaving a residue.
Don Orr
I've used peanut butter, regular butter, margarine and such to get gum out of hair. DAMHIKT. I imagine most any solvent like WD-40 (not really a solvent or lubricant) or similar might work.
