Removing old water rings.
My son just got some walnut end tables as a gift. Walnut, very spare design, maybe Danish Modern. Some sort of in the wood flat finish. One of them has two old dark ring stains in the top. The tops are veneer/plywood. Any suggestions on removing the rings? He wants to sand them. I am reluctant to do so because we don't know the thickness of the veneer. There is edge banding. Got any better less risky ideas?
Re: Removing old water rings.
Re: Removing dark water rings. *LINK*
Gary Smyth
Ran across this article. Clearly a test will be the wise action before going full bore. I've seen the Barkeeper's Friend dry can in a big box, but never used it. I do use store containerized oxalic acid to clean really stained/encrusted glassware. In liquid form use eye protection, gloves, mask, and a glass container. Even outdoors fumes can get to you. Do not store long term in an enclosed cabinet with paint--especially spray paint, or after some time even tightly closed acid container fumes will eat the can and you will get a nasty murder scene surprise when you open the cabinet door some day. Can also be used on boat scum after season. FOLLOW DIRECTIONS and Test. Test!
http://www.thomaspenrose.com/diy_stains01.htm
Thanks, I will try that. The stains I have to deal with are much less conspicuous than either of those. Just a couple of rings. The rings are about three inches in diameter and the actual stain is a circle that is about a quarter inch wide and not that dark. Maybe I have a shot.
Re: Toothpaste
Stuart Johnson
Try scrubbing them with toothpaste with a rag not your toothbrush. The toothpaste has a very fine grit and I have seen it work on cherry.
