Porch problem
james runchey
I've got a porch made of fieldstone covered with stucco or mortar on a early 1900 hundreds dutch colonial. it started life as an open porch with a wall about 30" high on the inside. It's topped with a flat sill 10 or 12 inches wide and in later years the porch was enclosed with a wall set on the sill smack dab in the center. When the house was sided they flashed about 2" out from the framed wall and i think maybe water is leaking under this flashing. Anyhow, a crack has developed in the sill and water is entering and lifting some of the stucco further down on the wall. I had patched the crack last year and now it's re-opened. I have two questions...I'm thinking if I could put some kind of a rubber sheet goods glued on top of the flashing and wrapped around the sill this would cure the crack re-opening and any water wicking under the flashing. The second question is what would I repair the places where the stucco has fallen away with, mortar mix, or something else?
