Re: Carving Fingers
John in NM
Not an abrasive one.... even diamond wheels are exceedingly mild in an angle grinder. It is simple physics.
The danger of such wheels as this is binding in a cut (steel or rock, I've done a lot with both) causing the grinder to flip on you and smash your fingers or whatever else is in the path, or even just wrench your wrist trying to control the thing. The blades themselves are mostly harmless (to shamelessly borrow from Douglas Adams).
With about an hour's worth of experience you learn to recognize the feel of the blade beginning to bind and it is easily corrected by keeping the blade plumb in the cut.
Come to think of it, the biggest danger of abrasive wheels is probably the dust and sparks rather than any kind of accident with the grinder.
Now a carbide toothed carving disk or saw chain disk - wouldn't get near one without the accessory handle, guard, and some heavy gloves
