Rot/bug question, do we have a chemist???
I have long used BoraCare and Timbor to protect against rot and insects (PPBs and Termites in my houses. I believe the active ingredient in each is Sodium tetraborate. BoraCare has it in a glycol solution and you dilute it and then spray it on. The Glycol acts as a carrier or penetrant and is poisonous and the same ingrdient as in some antifreeze. The Timbor is a powder you mix in water and spray on and it tends to sit on the surface.
I just realized that 20 Mule Team Borax is Sodium tetraborate. 99+% with a trace of other minerals. I have looked on the internet and found recipes for making my own BoraCare. Not sure I want to do that. Boiling anti freeze does not seem to be a good Idea.
I have also bought "Borates" in the form of little rods. You drill a hole and insert them into the wood. If the wood gets wet, they dissolve and soak out from the inside, stopping any decay. I have used them to treat the bottom six inches of door frames.
My question is, why can't I use 20 Mule Team Borax for this? Without all the cooking of antifreeze? Perhaps just drill a hole and stuff it full of powder? And, Can "WE" figure out a way to use it to protect freshly sawn lumber?
It would be MUCH cheaper. Perhaps 1% of the cost of the little rods.
(PS...It looks like Boracare Really does work. About thirty years ago I worked on a house and soaked the bottoms of the porch columns in BoraCare. I stood them up in a shallow pan and poured in about an inch of BC. Kept adding more for several days. AS I recall, they soaked up far more than I expected. Over the last couple of days I been working on the house next door. The columns are in great shape. Not so much for the rest of the house.)
Re: Rot/bug question, do we have a chemist???
John in NM
You can do that, though IIRC, studies show that the glycol is an important component. I believe you can substitute propylene glycol, it is relatively harmless stuff, used in food coloring and toothpaste among other things.
Easiest source of propylene glycol is pet safe antifreeze like Sierra, or the antifreeze for RV potable water.
Close, But
Timbor and Bora-Care are both made from Disodium Octaborate Tetrahydrate.
Borax is, of course, a borate mineral is "mere" Sodium Tetraborate, so you'd best check with a chemist before replying on those mules to kill bugs.
PS:
Just did a quick search on the question and it seems that borax, notably the 20-Mule kind, will kill grooming bugs (those that clean themselves) although it's not as refined or as toxic as the TIMBOR B/C active ingredient. Reminds me that we used to use 20-Mule for roach control in a commercial kitchen. A light dust along the baseboards and we stopped seeing them. Had to be repeated twice a year for about 2 months.
