curve layout & cutting
John Capas
I'm an amateur building a deck and need help please.
I have a 7 foot round Jacuzzi in the middle of the deck, sitting on a concrete base. Jacuzzi extends 12 inches above the deck floor. The deck consists of 2 x 12 pressure treated joists with framing around Jacuzzi. The deck will be covered with 2 x 6 pressure treated decking spaced 3/8 inches. I need to know what is the best way to lay out and mark the curve on each 2 x 6 to follow the curve of the Jacuzzi. Each 2 x 6 will need to be marked and the curve cut individually with a jig saw. I'd like to leave 3/4" space between the decking and Jacuzzi. The space should end up being even all the way around the tub. How do I accomplish this?
Thank you very much for your time.
Re: curve layout & cutting
There may be an elegant way but not knowing it I would temporarily lay the boards in place, use a string and nail or stick with a nail as a compass to mark the circle on these boards and then saw.
Since your tub surround is in place, bring each deck board up to and touch the side, then use a piece of 3/4" stock as a spacer to scribe a line on the deck board for your jigsaw. Be mindful of where the other end of the deck board ends up vis-a-vis joints so that you can minimize waste. At some point your 3/4" spacer will not be thick enough, so then double or triple it as needed to reach the longer point on the deck board.
BTW, unless you're using double kiln dried decking, 3/16" gaps will be fine as your deck boards, holding high moisture content from the treatment process, will shrink and the gaps will open up. 3/8" will likely become 1/2" wide and might pose a tripping risk for some people. When using PT decking, I use a series of 20d nails to set the gap. Works just fine.
You mean the Jacuzzi is already in place and you have to build around it, or it will be installed later?
If it is already in place: I built a deck around a round swimming pool like that. I don't know if the method I used will work for you, but this is what I did. I designed the deck to be hexagonal and the boards on each side were oriented more-or-less radially towards the pool. The pictures below might give you the general idea of the design.
I made each board a bit longer than finished size, slid it up to the curved surface, then marked a line for the clearance. The circle of the pool was large in this case so the ends could be straight but angled cuts. For a smaller circle with precise 3/4" clearance, I think I'd rough-cut an angle on the end of the board, slide it close, then use a compass to mark a pencil line for the cut.
In my case, I let the board overhang the edge of the deck and just trimmed to a straight line.
It is likely your boards are not radially aligned! In that case, marking the radius of the tangential boards will be more challenging. In this case, I might consider taping together some large sheets of paper or cardboard (or thin ply/luan), draw the circle, then use this as a template. Or make smaller templates as you put down each board.
Two things I've discovered over the years about building decks from pressure-treated wood: one, it's generally a waste of time to make things too precise. The boards will shrink and warp. The last person who will look critically at the details is you when you build it!
If I did want it pretty I might try to think of another way to do this, for example cut a sloppy gap then cover it with some finely crafted trim.
Sorry, I don't have good closeup pictures:
BTW, these decks were fun: 7 levels, ~1500 sq ft, most levels at the house built on a 17 deg angle, built in the summer when the most days were over 100. This was my first try at deck building.
Large gap
Lee Schierer in McKean, PA
In my opinion you will regret the 3/8" gap you are planning between boards. Treated lumber is pretty wet when you buy it and it will shrink width wise when it dries out. This drying will increase your gaps to 1/2" or more. I would recommend leaving a smaller gap, say 1/8" between boards, which is sufficient for water drainage and it won't create gaps that will be too large later on.
Lee
Re: Large gap
I agree with Lee and Mark and anyone else warning you abut the gaps. I have built a lot of decks over the last forty years. With 6" wide stock, whether deck boards or 2 X 6", they will shrink enough to create a proper gap. 1/8" or 3/16" is plenty, maybe too much. With the round edge deck boards I lay them tight, edge to edge. They shrink enough to create drainage gaps. 2 x 6's might benefit from a small starting gap. If the gap gets too wide, women don't like it because they will trap the heels of their shoes.
As to cutting the space around the tub. Sneak up on it. lay decking up to the point you have to cut a board. Lay the board that needs to be cut exactly on top of the last board that did not need to be cut. Use a scrap of deck as a scribe strip. Slide it around the tub and use a pencil beside it to mark the cut piece. Cut it and slip it into place. Then use a narrower strip to mark the actual space. The reason I say to cut it twice is that my recollection is that the appearance of the space changes when you move the board in relation to the tub. Try it and see. My other thought is that 3/4" may be too much hear. It will open up as the boards shrink and may be a place for fingers and other stuff.
The shrinkage as it dries is ~1/16" per 1" of widt
Keith Newton
So just under 3/8" for 2x6. One thing I've found to be handy, is to use a speed-square for the spacer. When the next board is in place ready to be screwed down, slip it between, resting the thin end on a joist, and the T wings up on the deck. After it is fastened, most of it is above deck and easy to grab and pull out. This is really handy when you've had to lever over a bowed board.
2x12" framing sounds like overkill, unless the span is over 16', and not supporting that tub.
Also, I would not use 2x6 for the deck, rather than 5/4" deck lumber is plenty stiff and looks better. Most 2x6 will have more knots and heartwood, which prevents the chemicals from penetrating, leaving it more prone to decay. The HD and Lowes in my area offer a clear grade. The premium grade is a better deal if you figure it out over the long term.
Lastly, be sure to use coated fasteners that won't corrode away from the chemicals. I've started only using one screw per joist crossing, staggering from on side back and forth down the length. On Many of the decks that I've replaced over 40 years, the tips of the joist were cleaved open from too many fasteners. This allows the crud falling between the planks to build up in that upward facing gap capturing water as well. Near the ends, I use two screws, but avoid hitting the center line of the joist with all, by slightly staggering .
Kneale Brownson
Avoid PT around tub
Kneale Brownson
The chemicals can raise havoc if splinters get into bare feet.
Not knowing the orientation of the joists
Gary Smyth
it seems to me that Bill has the solution. If the diameter if the Jacuzzi is only seven feet or 84" I'd get to a driveway or other flat spot and mock up on the ground that 10 foot section of the deck. You may want to chalk, string, or drywall tape out the joist position underneath too to make sure the decking can be attached properly. Use a rod at the center (to precisely indicate the center of the Jacuzzi), a accurately measured 3 1/2 foot string or preferably a solid board with a hole for the chalk as a compass arm and chalk out the outline. Do another line to get the jacuzzi to deck gap you decide on. Using whatever decking you finally select and adjusting the gaps on the ground beforehand will make it simpler for the permanent fitting. Number the boards.
Admittedly. if you have varying board widths and bows and twists this might not work if unsecured on the ground. I'd bite the bullet and get stable water and chemical resistant decking to get the result you want. Depending on what decking you choose you can work with the gaps between boards. Growth rings are down if using lumber.
Re: Avoid PT around tub
George Koch
I would fit each board individually by placing it up to the tub and scribing and cutting it to fit before cutting it to length on the other end. Also, I've had many more infected splinters when working with cedar or redwood than I've ever had from treated lumber.
William Duffield
Maybe the pressure treating chemicals kill whatever infectious agents might be carried through your skin by the splinters?
Bruce, a MN Galoot
Years ago when I built my canoe from cedar, I thought my hands would never heal.
