Old Tungoil - should I use it?
David C. Lykins
Well I finally got back to doing some wood working, though my tools are limited and I have to set up my portable router and tablesaw for every use. Anyway, I'm in the process of finishing a Black Walnut and Ash Watch Box for a friend of mine as a birthday present. Now I'm trying to decide on what finish to use. I have some shellac made from blonde shellac flakes and some old tungoil. I tested both the shellac and tungoil on a piece of black walnut. However, the tungoil, and I'm assuming because of its age, had sort of settled, it had a white milky sediment at the bottom of the bottle and light honey color at the top. I mixed the tungoil as best as I could and applied it onto the Black Walnut. Its seems pretty thick to me, however the finish seem fine with the exception that after a day of drying, I still had to wipe off the access tungoil.
So do you guys and gals think the tungoil is OK to use (it's now a tan milky color), or is there anything I should do to the tungoil, like heat it up or something to make the mixture better.
As far as an end result, the tungoil does come out a little darker with a higher gloss than the shellac after applying two coats (I'm assuming I'll need 4-6 coats no matter which I choose to use) of each finish.
Any information is greatly appreciated.
Thanks!
