ADVERTISE HERE - FREE TRIAL
problem with pressure balanced faucet
The tub faucet, Delta, is pressure balanced. The flow on the cold side has become a dribble. Hot side is OK. I have taken everything I can find apart and cleaned- ball, both cut off valves, shower divert, pressure balancing assembly. Still have the problem. I removed the guts of the pressure balancing assembly and get a good flow of warm water at all positions of the ball control. Put it all back together and get only a dribble when on full cold.
I have no idea how this thing works.
Re: problem with pressure balanced faucet
Mark Nowicki
I have no experience with a pressure balanced faucet but I have had good experience with Delta service.
Call them, they will walk you through the repair steps, or send you replacement parts.
Calling Delta is a great idea. I have had a similar problem on an older problem and a newer one. On the older one there was a piece of white plastic trash in the line. The faucet was installed in 1979 and the problem occurred about 25 years later. No idea how the trash got in the line. When I turned off the supply it would drop back down out of sight. With the water on it woudl flow up against the rear of the faucet. After about five disassembles and reassembles. I turned the shutoff valve on with the faucet disassembled and blasted it out of there. Fortunately I had just enough sense to pull the shower curtain and I found it in the tub. I still wonder where it came from and how it got into the pipes.
Newer faucets have a temperature control. They must be assembled correctly and there is a limiter ring. Memory fails me, but if the cartridge is inserted wrong you can get hot and cold reversed (???) and if the limiter ring is wrong you can get reduced flow. I have done about five of these on rentals and you woudl think I woudl know by now but its all mysterious and I just sit and follow the instructions. I do know that the renters hate the limiter and want the faucets set to as hot as possible. I do this just often enough to be bad at it.
Call Delta
Re: When Calling Delta
Best to have the model number off the valve before you call; the tech will ask for it. If you have the documentation for the unit it's easy, hunting around in the wall hole with a light and inspection mirror is not. The T/P cartridge may have the number cast into the body.
got it #603
I have one of the earliest pressure balanced fixtures. It does not have a cartridge. Rather it has a housing into which a complex multiholed and o-ringed cylinder fits that has in turn a stainless inner cylinder with again a multitude of holes. I have disassembled and cleaned everything I can remove and still the problem persists. It must be something internal that I can't get at. The next step after calling Delta may be 90 pound air to be blasted into every opening I can open.
Lee Schierer in McKean, PA
There was a problem with a faucet at my daughters house, where there was plenty f water from one side of the faucet, almost no flow from the other side. I took everything I could find apart and even called the company service number. Nothing helped.
Finally, I pulled the faucet out and lo and behold on the bottom inlet to the faucet there was a really fine screen that was completely clogged with a slimey substance. After scrubbing this stuff with a small stiff brush and rinsing, I reinstalled the faucet and it worked perfectly.
The only way to get to this screen was to remove the water supply line. The screen did not show in the parts explosion for the faucet, but was definitely factory installed.
Lee
Limiters...
John in NM
I betcha that is it if Bill's is new enough to have one.
Any idea when they started putting those in? I have to put new seals in ours one day soon, and I bet it has some of this foolishness going on inside too. Its enough to make me wonder if part of the strategy is to discourage repairing and encourage wholesale replacement of dripping faucets!
I fear you are correct
and doing what you did will involved major deconstruction of the bathroom
Times Have Changed
When I worked with my FIL (a master plumber), I had to learn how to use the various tools he used to "REPAIR" valves, from in-place remilling valve seats to honing a cylinder and replacing O-rings, to valve stems and packing, the task was to make what you had work again. Those tools are obsolete now as plumbing has charged to a series of gripping tools needed to just remove and replace the whole fixture.
Had a t-p valve in our master shower go bad. Even though I had replumbed the whole house when I did the master bath, Memsahib wanted a license to come in for the fix. All he did was pull the trim, cut off the service stops and the remove and replace the cartridge. 15 mins total and it cost me easily 5 times what a replacement cartridge alone would.
[sigh]
Re: no, this faucet has worked for 21 years
John in NM
Ok, so not a hot limiting faucet? I gathered Barry might have it from what you said about taking the guts out and getting good flow of warm (rather than hot) water.
Re: I fear you are correct
Are you on a well? I had a house where the water flow to the washing machine dropped away to nothing. There were strainer screens in the hose washers. They were packed with sand. Took the strainers out and ran the water into a bucket. Literally got a gallon of sand. Ended up re-positioning the pump in the well and later redrilling the well.
Mark Nowicki
No access panel behind the faucet?
No, in fact there is a built in cabinet behind . I would be a massive job to replace.
