THE WOODRAT IS BACK!
type of hard board
type of hard board
type of hard board
eliot feldman
I friend of mine has some Festool work tables. If I had to name the wood, I would call it high density fiberboard. But I don't know what it is. It looks very dense and hard. Does anyone know what this stuff is and where to get it.I'm pretty sure it's not MDF.
Re: type of hard board
Jesse Cloud
The Festool tables are made of MDF, but mdf has various grades of density. Festool uses a high end mdf. The mdf sold at a good lumberyard is close to what Festool uses. The Home Depot mdf is less dense, more porous and more prone to
sag - fine for some uses, poor for others.
eliot feldman
Aside from hoping that the good lumber yard has the better stuff, is there some designation for the higher grade MDF in order to get the better stuff?
Re: type of hard board *LINK*
Clifton C
I've used MDF for paint grade built in units. Construction was mostly screwed and glued, actually tacked with a finish nailer, pilot hole drilled, then screwed. The heavy stuff is heavy, go figure. The ultra lite works great the higher up in the building you have to carry it. Dentability is fairly durable on the face and a bit less on the edge as would be expected. Edges where taped with paint grade thermal edge banding or face framed. We used Bondo where we needed to fill a seam or screw hole. It gets a bad rap, most people hate it but it has its place. Good dust collection is a must...
cc
MDF
John McGaw
There is no reason that it might not be HDF. I used that for my first bench although it was just a replaceable skin over a well-braced 3/4" substrate. The problem with the high-density stuff for big self-supporting surfaces is that it is invariably thin: 5.5mm seems to be about it. The tempered stuff sure it tough though and held up very well under heavy usage.
