Some more bandsaw questions????
Are any of them less fiddly?
I have a Delta 14" saw with a riser block. I have Carter guides, a release lever, Kreg fence, etc. I have adjusted to be coplanar when the blade is on and under tension.
I just spent 45 minutes putting a blade on it. Changed one 1/2" 3 TPI blade for a similar one. Who thought it was a good idea to require two or three different Allen wrenches to adjust the guides? Every time you turn one of the screws the bearing moves. Why are there not knobs? Who put the fence adjustment bolts "under" the fence?
I spent more on "upgrades" than I did on the saw.
Is there a saw out there that makes more sense? One where you can adjust things without assembling a little tool kit? Or change the blade without dissembling the saw? Where you can change from slicing veneer or resawing to cutting a bowl blank in a few minutes? Apparently I need two bandsaws.
