Bedside Chest of Drawers
Daughter needed something beside their bed, his and hers. She found something she liked and submitted it to be added to the list of stuff to make. It has become the project from Hell. Why? I’ll deal with that later. The sides are made from a veneered panel inset from the frame whose horizontal rail is in turn set in from the vertical members. Each post has 4 mortises, 2 dovetails and a dado, plus rebate for the back member. That is a lot of investment for each piece and the complexity invites a screw up. It is ever so easy to cut something on the wrong side or wrong end.
What wound up to be piddly M&T’s for the frame served to align it more than strengthen it. The rigidity comes from gluing the panel into the frame, a realization that revealed itself late in the assembly as I chopped away ever more of the mortise and tenon to accommodate the panel.
Liquid hide glue saved the day with glue up. It lubricated the multitude of joints and its slow set enabled the assembly to be glued up and adjusted. If you consider how this thing is put together there are no degrees of freedom like in a normal panel that floats, or in the reveals of the offset rail and panel. It either goes together perfect, or not. It did, to my relief and as a result of many dry fits. The rest of this piece is straightforward, thankfully.
One of the annoyances of Irfanview is that when you aren't looking it defaults to saving files in B&W. To lazy to redo them.
