My Powermatic 66 TS
My Powermatic 66 TS
My Powermatic 66 TS
eliot feldman
I thought I read somewhere that this TS is designed primarily to cut large sheets of plywood. Is this true? In what sense could it be designed differently for that purpose? How would it differ from one not designed. particularly, for that purpose?
Re: My Powermatic 66 TS
Mark Nowicki
Not true.
eliot feldman
I pleased to hear it!
Thanks!
Keith Newton
Yes back when this saw first came out, most cabinet shops that bought them, were cutting full sheets of ply, making the components for their cabinets. Getting the wide table and bar for longer fence to blade was next, which really helped.
Then some shops started jury rigging sliding tables, but I don't know if that was really worth the effort.
Now in larger shops, as well as some smaller shops, large CNC panel saws cut big stacks of sheet goods to very fine tolerances.
If this doesn't answer you question, try to be more specific, and tell what you need, as well as what you already have.
I don't actually know, but I think cutting plywood down to size was a use that just "emerged". A piece of serendipity. Cabinet plywood became available and insinuated itself into the cabinet trade in particular. Then you have to break it down. A saw with a large surface and huge movement for the fence suited the purpose. So the PM 66 was available with a 55" +/- rip capacity and emormous wings. A large outfeed table makes it easy for a single person to break down and entire sheet along.
About forty years ago I modified the fence on my ancient Delta Rockwell cabinet saw to be able to cut 36" rips. Specifically so I could cut cabinet ends. Later I got a Beismeyer fence and was disappointed it will only rip about 30". It just seems so obvious to be able to rip cabinet ends that I have never understood why they chose 30"?
Back to your saw, there is nothing about the modification of the top to the size of an aircraft carrier the negates any of the functions it would have been able to do with the once standard top and fence system.
eliot feldman
I don't have any issues with my Powermatic 66. I purchased it years ago with a 3 HP motor, but a mover managed to drop it from a height of about 4 feet getting onto a moving van. So the insurance co. bought me a replacement with a 5 HP motor at no extra cost. I love the saw; and now that I have some explanation about its width etc., I can see that someone may say that it was designed for large pieces of plywood. I was wondering if I was missing something that would be emphasized for a TS that didn't particularly feature this feature.
I take back what I said about no issues -- there's one. I have one of those box-like add-ons that are made to improve dust extraction. It attaches to the left side of the saw (as you face the saw in the usual position.) But I have never been able, with a 1 1/2/ hp dust extractor and about six feet of 4 in. hose, to get any satisfaction about dust extraction. Maybe it gets the fine stuff. But if I put a small piece of paper or something near the throat plate opening, not much happens.
Dust
Eliot,
You can increase the dust removal on you cabinet saw by taping up the line where the cabinet body meets the saw top. You can also use a strip of magnetized rubber like the stuff they use to make temp car signs to close up the slot where the elevation wheel travels when you tilt the blade. An over-the-blade suction port/ blade guard will help as will using zero-clearance throat plates, and lastly, set your blade height so that the teeth just clear (1/8-1/4") the top of the board you're cutting. Small safety gain being less chance of blade finger contact.
Re: Dust
I agree with Mark, but do not totally carried away sealing the saw. You gotta have GOESINTA to get GOESOUTA. Dust collectors are basically low pressure high volume machines. They have to get enough air moving to make the pickup and flow the dust to the bag.
I worked pretty hard to have effective dust collection on my Contractors saw. At one point I considered putting a compressed air nozzle beside the blade to blow the dust cross wise out of the gullets. Also though about doing it with a shop vac.
Without that goofy stuff I got mine tot he point the only thing left to improve the situation would be an over the blade pickup. I decided that clean/dust free and wood working shop was an oxymoron.
Re: Dust
His 1.5 collector and a 4" hose will be helped if he can channel the airflow towards the dust port. The spinning blade actually moves a bunch of air down into the cabinet. With the cabinet sealed to the top he will force the flow to increase around the blade and throat plate. The elevator slot won't seal anyway so there should be sufficient volume to increase the velocity of the air. With more energy in the airflow he should get better collection. After upgrading to a 6" system, I get upwards of 1,800 FPM through the 4" ports.
Re: Dust
Again, you are correct and I agree.
Dust collection on a TS is all about capturing the particles coming off the blade. They are moving fast and hard to redirect with air flow. The smart move might be to let them impact some surface and spend their energy and then pick them up. The Blade tends to throw them toward the rear of the saw. So it might be wise to use that to your advantage and capture them going in their "natural" direction. We could and have gone on and on about this.
OTOH, it has been said the really dangerous particles are the ones you can't see. Its the tiny ones that get you. This is what air cleaners and Personal Protective Gear are for. Air Cleaners are controversial in that they may keep the particles flying longer and give you more time to inhale them. Wear the PPG.
Containment
Had a Ryobi BT-3000 that had its blade running in a "tub" that incorporated a dust port for a shop-vac and moved with the blade when in tilt-mode. Even using a shop vac, there was actually very little dust falling below the saw and, with the blade set to minimum height, not a whole lot above the table either.
Always thought that the tub/shroud/etm was a good idea and wondered why more saw makers didn't incorporate some variant into their cabinet-style offerings. Would be hard to do on a "classic" contractor-style machine, but I've yet to meet a contractor that cared much about how much dust they make given that most job-site saws seem to get set up outside.
Except for the geared belt and the aluminum top's streaks, the Ryobi was a pretty good saw and would do quality work if kept adjusted.
Re: Containment
I made a "tub" for my Delta Rockwell contractor saw. Its a box with an end boot on the bottom. The box has a sloping top angled to allow the saw to tilt to a full 45. The blade rises through about a half inch slot. I oriented the boot to come out the front of the saw so the blast gate would be near the switch and in easy reach. The Blast Gate turns the DC on. I would say it gets 99% of what the blade drops in the box. And it pulls off a lot of what the blade would throw out of the top. An amazing difference With the DC ON and OFF. Once in a while I forget to open the gate and after few seconds of being sprayed I am reminded to Open the gate. It might work better if the boot were turn out the back, but then I would have to walk around the saw to operate the gate. I have a tiny shop and could not bring myself to add an over the blade pick up. I did dangle a pickup from the ceiling as an experiment, but the difference was so marginal I nixed it. I think part of the problem was the second port reduce the suction to the tub.
