Switch Converson
Switch Converson
Switch Converson
Gordon
I have a Delta 28-275 14 " band saw with the standard toggle style off-on switch which I would
like to convert to a paddle switch that would be attached to the upper frame assemble.
My question is: How would I wire the stock Delta motor to accept the new switch?
Is there a wiring diagram for this type of conversion?
Thanks for any help.
Gordon
Re: Switch Converson
Rick L
Rick L
The wiring diagram on the motor has no bearing on changing the switch unless you are converting 120 volts to 220 volts. Open the pitch and follow the wiring that's already there. 120volts is a single pole switch. 220 would require a 2 pole switch.
Gordon
My current switch wiring is for 120 Volt and my main concern is how the wiring is connected inside the motor where there are two sets of connections coming into the motor from the original factory toggle switch.
Gordon
Re: Switch Conversion Pictures ?
ChuckInND
Pictures would be nice. I have to go along with what Rick said, and if you can't figure it out, then call a local electrician.
Larry
If you aren't changing the voltage then follow to wires from the old switch.
Keith Newton
Still, you should not need to change anything in the motor.
In the switch box, you can wire the whites/ neutrals together, then just hook the two black / hot wires through the switch.
Gordon
Thank you for all the valuable information.
I think what I will do is to upgrade the motor to a motor with more hp
and this way I can do the switch conversion.
I need the horsepower for resawing.
Thank you everyone.
Gordon
Re: Switch Converson *LINK*
walta
I have use 2 of these switches from Rockler they have worked fine for me. They are rated for 15 amps. I have one on a 1.5 horse motor it has held up so far but that is beyond its rating.
The one thing I do not like about the switch is that should the power go off when the tool is on, when the power is restored the tool will not automatically be turned off so the tool may start running when the power is restored.
When you are shopping for your “paddle switch” be careful you do not buy a “control station”.
A “control station” contains 2 switches but they must be connected to a “motor starter” in order for the start and stop buttons to operate the motor.
Walta
Rockler Switch
Gordon
Thank you Walta for the link.
This is a similar switch of what I was going to use when I do my upgrade.
Gordon
