THE WOODRAT IS BACK!
zero clearance insert splitter
eliot feldman
I have two such throat plates that I made. One is MDF and the other two are made from some 3M product that's no longer available. It used to be used for locomotive floors. (Very hard black laminated stuff.)
I'm making still another throat plate for another blade.
Do you recommend that the width of the splitter exactly match that of the blade it was made for? Or perhaps a shade wider? Or perhaps not wider, but offset a tiny bit closer to the fence. I have used washers that are glued in and also those little green plastic thingies, which you can take in and out. But the prongs are always breaking off on these. I could glue in one of these broken ones, but then you can't take it out.
How about using a little metal cylinder? e.g. an old 1/8 inch drill bit for an eighth inch blade. Perhaps two of them in a line , each one offset a tiny bit left and right? They could easily be taken in and out.
How have you done yours?
Re: zero clearance insert splitter
David Bair
If you make your splitter wider than your blade, you're going to bind up on every cut trying to push a board with a 1/8" slot around a greater-than-1/8" object.
eliot feldmqn
Of course, I see what you mean; but I thought those little green splitters were a tiny bit wider than the blade. Or is it that they are just a tiny bit offset? (Talking about a few thousandths.) My impression was that the idea was to get a feather board effect.
Riving knife vs. splitter
Gary Smyth
Riving knife versus splitter from Wiki so only to provide basics. If something different you can add if you wish. Don't make things more difficult than they have to be.
A splitter is a stationary blade of similar thickness to the rotating saw blade mounted behind it to prevent a board from pinching inward into the saw kerf and binding on the saw blade, potentially causing a dangerous kickback. Like a riving knife, its thickness should be greater than the body of the saw blade but thinner than its kerf.NOTE: BODY of blade, not the tips. Blades with a narrow kerf relative to their body are more susceptible to grabbing and kickback.
A riving knife has numerous advantages over a splitter:
It does not need to be removed from the saw when cross-cutting or doing a blind (non-through) cut as it does not extend above the top of the saw blade. If it is not removed, the operator cannot forget to put it back on.
It sits closer to the back edge of the blade, making it much more effective – less space for the stock to shift into the path of the blade
It provides some additional protection for the operator – blocking contact to the back edge of the blade – in those situations where the stock is being pulled from the outfeed side of the saw.
It is independent of (and will not interfere with) other blade guards and dust collectors.
A featherboard is a sprung finger that applies pressure holding the workpiece against the saw table. It can reduce the risk of a kickback developing, but will not restrain the board if one does occur
I have used the Micro jig splitter for several years, they have served me quite well. Yep, I have broken a few but replacements are pretty cheap. Some of mine are offset by a few thousands. I have had a sprung board close up and lock on the splitter, but still did not have a kick back. Had to shut off the saw and pull the board and splitter out and drive it out of the slot but no damage.
Son and I won't use the saw without the Grr Ripper system and micro splitter. I have had to rebuild the Grr Ripper a couple of times but much rather do that than have a kickback or injury.
I built several Zero clearance inserts at one time a few years ago, still have a few left.
John in NM
I just raise the blade through the blank and don't worry about it. I guess I do have one thicker blade (a Forrest) that I use when making inserts - there is a gap in any case even if each blade is matched to an insert, because the teeth are wider than the plate.
I have one of those plates with the replaceable strip for the blade to go through. I don't think anyone makes those any more, but they are handy - easier to make that strip than a whole insert.
Re: Riving knife vs. splitter
eliot feldman
I suppose, then, that a steel blade with no carbide tips (so that the blade and teeth are all in the same plane) would be the most dangerous from the kick back point of view. I never thought about that.
Steel blades had the teeth "set" or bent in alternating directions to create clearance for the plate. I also had some that were "hollow ground" so the plate was thinner than the teeth even though they were not set. Can't remember ever seeing one that did not have set or hollow ground.
Sad Note. I took my hollow ground finish blades to a red neck sharpening service and he set them. Rather rankly. Pretty much the end of them for any finish work.
Not Necessarily
You forget that a steel-tooth blade 's teeth are "set" to one side or the other in order to cut. That blade body may be 1/16+" thick but the kerf will still be 1/8".
I set my drop-in splitter to be dead nuts co-planer with my saw blade's fence-side surface and exactly the same distance from the locked surface on the fence as the back point of the blade body. The distance, BTW, is .002 more than the distance at the front of the blade to help prevent baqsheesh.
Sgian Dubh
Gary, the Wikipedia entry you cited isn't definitive. Not all riving knives have a top point that sits lower than the top arc of the blade's diameter as described in that entry. Some do, and some don't. Those that do end lower usually have crown guards attached to some sort of a cantilevered mount that reaches across from the edge of the saw table to overhang the saw blade. In this case, non-through cuts can be achieved with both the riving knife and crown guard left in place.
The other type of riving knife has the crown guard attached directly to the top of the knife. This necessitates the knife extending over the top of the blade. In this latter form, executing non-through cuts requires removal of both the riving knife and the crown guard. Slainte.
eliot feldman
I just finished one. I just glued in one of my broken little green splitter things. When cutting a board with it, it definitely felt too tight; so I kept filling off a bit on the right side (closest to the fence) until the board went through smoothly. This one can't be taken in and out, though.
Points well made
Gary Smyth
My limited defense is that I quoted and credited Wiki and Wiki is not always dead accurate. Readers would do well to consider your response when making decisions.
