I think differently
Grant in Iowa
Your mechanic is correct in that modern vehicles, including your chevy are actually dipped at the factory in a rust inhibitor/ primer product. The frames are also treated and undercoated. This is all fine and dandy, until the salt season comes.
Note that you have a nice looking truck, presumably not driven in winter much. All the same, it has hard to see little chips and nicks all over it and underneath. These will begin rusting IMMEDIATELY once it sees salt season. I had a Chevy van that was mint looking at 8 years old. Then I moved from California back to Iowa, and it rusted at a rate to quickly catch up to Iowa vehicles of the same vintage.
I recommend you look at other trucks of the same model, and notice where they are beginning to rust. I had a 2003 silverado, and it began to rust out at the rocker panels and over the rear wheels. I sold it and I now have a 2012 silverado that I have treated in the following way:
I bought a kit that allows a do it yourselfer to apply a product called fluid film. Fluid film is a sort of thin grease that comes from processing sheep wool. This stuff can be sprayed on and in nooks and crannies on your vehicle. Rust needs two things to happen: air and moisture. The product claims to limit the amount of air and moisture that come in contact with the metal. It remains fluid, and as such will just keep moving around inside the back side of the panels and where metal meets metal. I am sure it will help, just not sure how much.
I bought the sprayer that works with an air compressor, and a gallon of the product, along with a long bendable wand that goes on the sprayer. My truck has all of the factory plugged holes where undercoating is sprayed inside the rockers and inside the frame and under the rear wheel wells, and in to the tailgate, etc. I spent a couple hours in a tyvek suit on a creeper under my truck spraying everything that I could access, paying special attention to those common rust areas. The stuff shoots out of the gun looking and sounding like a kid with a bad cold.
How well does it work? Dunno yet, too soon to tell. And you need to reapply every couple years to key areas.
I also added rear inner fender liners (available from GM for $100 for both for my 2012), and added some 3m rock guard stickers to areas that get hit with rocks often. I also touched up any rock chips the already truck had when I bought it with 10K miles.
You can also buy at home centers clear plastidip spray that can be applied to masked off areas where you expect rock chips may occur. Some do this to alloy wheels and such each winter, as the product can be peeled off easily if applied thickly enough like a bad sunburn. It just looks like an orange peel texture atop your paint or wheels. Easy to do if you don't mind laying on the ground for a while.
Vehicles are expensive, and I spent a couple days doing all of this on the 2012 silverado because if I can make it last a couple years longer, that is money in my pocket.
Congrats on the new wood hauler, now get out there and protect it!
Regards,
Grant in Iowa<---Shhhhh!, you hear that? I can hear stuff rusting!
