Gluing Oily Woods
Gluing Oily Woods
Gluing Oily Woods
Larry
What Glue do you use to glue Oily Woods like Teak and Apitong ? Will be outside.
Thanks
Re: Gluing Oily Woods
2 Steps
After final sanding and cleaning:
1. Rinse/Wipe gluing surfaces with lacquer thinner or acetone
2. After dry, glue with good quality epoxy like West or System Three using medium or slow hardener [no 5-Min crap here!] and clamp over night.
Alternative glue would be Resorcinol two-part marine glue.
Re: 2 Steps
GolfSteve in Calgary
I'd say:
1. Rinse/Wipe gluing surfaces with lacquer thinner or acetone until there is no longer any residue showing on your rag. I think the idea is to wipe the surface to remove all oil, then quickly glue-up. For rosewood, this can take several minutes of wiping for a small glue joint.
This has been discussed a thousand times without consensus, but I think a quick wipe with acetone probably just smudges around the surface oil and brings new oil to the surface.
Personally I think a quick sand and de-dusting before glue-up works well with rosewoods and cocobolo. For interior use, titebond, fish glue, hot hide glue, and epoxy all work well. For exterior use I'd use epoxy.
I've never used teak or apitong, so can't comment on those.
