when does watco danish oil expire?
Ryan
I've got a can of watco danish oil and I think it's pretty old . Is there a way to determine when it was manufactured? Secret code on the can or something?? I don't think my local retailer turns their stock over very quickly....
Re: when does watco danish oil expire?
It doesn't
John in NM
Basically its fine until it turns to jelly. You may see different results with very old oil vs very new, but only if the can has been opened.
I used to use some that had been sitting at work, half used up, for 15 years or more. It was more like a thinned varnish than an oil at that point, probably because solvent was gone or it had pre-polymerized or something.
I remember being unimpressed with Danish oils when I've bought them new, and that can at work I wish I still had.
Re: It doesn't
walta
I have had Watco die as John described I think there was a lot of the product had been used and this allowed in enough air in the can to gel the finish.
I also have had Watco die of old age. The old finish will not cure fully so the work always feels gummy and sticks to things. I think it was over 10 years old.
Walta
The old stuff I had sure didn't "die"
John in NM
It would skin over in a jar after a couple months, but it was an excellent wiping varnish at that point, way better than what I remember coming out of a fresh can.
I've never had any oil varnish go bad and never cure - though I live where its very dry, so perhaps it has to do with moisture.
TomD
I like that it is really thin. And it is polymerizing I think so if it starts to gel it is getting cross linked, and it wouldn't be making those bonds in the wood.
I have this ten gallons of oil that Michael Fortune put me onto. It rusted in the can, but so far so good, makes a really nice stain on maple.
Re: The old stuff I had sure didn't "die"
William Duffield
I've never had old Watco gel either, but I always follow the directions and wipe it on, let it sit a while (about a half hour, if I don't forget it for longer) and vigorously wipe it off. Same experience with BLO. OTOH, Waterlox, a varnish that will build on the surface, definitely will gel and become useless if you don't keep the oxygen away from it. I use Bloxygen, but squashing the can until there is no room for air also is effective.
Jim Dillon
Ryan, I've used some pretty old Watco (15+ years, both natural and walnut flavors) and it seemed to work OK. Shake the walnut to distribute the gilsonite. IIRC, I didn't let it set too long (maybe 10 minutes) then rubbed like crazy to remove the finish. Maybe it was a little harder to remove than fresh stuff. My biggest problem was getting the darn cap loose as the Watco had congealed around the screw cap. Had to use the channellocks. Jim
