table saw for a jointer?
eliot feldman
It just occurred to me-- and , come to think about it, I have not seen any references to it, but why not use a table saw with the widest dado blade to flatten one side of a board? Multiple passes.Then register the newly flattened side in the planner and flatten the board. Turn it over in the planner and pass it through again to smooth it up. Obviously for a board somewhat wider than your jointer but less wide than your planner.
Re: table saw for a jointer?
Yikes
I'll bet someone on YouTube can tell you how to do this, but it gives me the willies. How would you take the twist and cup out?
Re: Yikes
How?
You put a '63 Beatles song on the hi-fi and, as the board twists through the air with your body part, you shout "Call 911!!!!"
Gentleman needs to learn to use sleds and wedges.
Jason in OC
What happens as you finish the process? Most of your board is hanging in the air, and you're cutting away the remaining support.
My first thought was of the cabinet shop down the hill - the guy told me their big cabinet saw made such a perfect cut they saw no need to replace their jointer after a shop fire.
Then I too thought "Yikes!" I personally think that method would be full of functional and safety issues. Don't hurt yourself - I have a spare jointer you can borrow.
Jesse Cloud
Use the table saw or a band saw to rip the board into pieces that will fit on your jointer, mill them, then glue up, scrape off any squeeze out and plane.
Life is too short to take risks in the shop.
My first carpentry job was 50 years ago as a helper in a big shop. There were six carpenters. None had all their fingers, few had much hearing left. At the end of the day we all blew black mucus out of our noses.
I think of those guys when I evaluate safety in my shop.
Re: Yikes
eliot feldman
Yeah, it's a dumb idea! I had the vague idea that you could start down the center.
Re: table saw for a jointer? *LINK*
Denny
Build an adjustable planing sled and just use your planer.
planing sled
Save yourself some wasted effort and time,
Keith Newton
and buy a power-plane for the lumber wider than your jointer. Even a cheap one will be better than this idea. Or if this is a hobby, don't even bother with buying a small stationary jointer, but rather buy a larger Makita 1806B. You can surface really wide boards like you would with a hand-plane, but a lot less effort.
router sled
I'm with the others. Table saw would be a no no. board could rock and be thrown, one end could drop down and take a bigger bite, thrown board or damaged wood or both. There are lots of other ways to flatten a cupped or bowed board. I'm a router nut so I would build a sled out of angle iron, put the board underneath and route it flat. Well actually I would probably use my scrub plane to get it close. I could do that faster than finding the angle iron and building the jig.
eliot feldman
I still think I can do it, after all. The idea would be to glue runners on each edge of the board to be flattened so that the bottom of the board is just a bit above the top of the dado blade. After multiple passes to flatten one face of the board, one would cut off the runners and repeat for the other side. It would work for a board that's even wider than your planner. I can't see anything wrong with such a procedure, but one should take light cuts with the dado blade and use a serious feather board. And, of course, it would be very important to make sure that the glue is dry. If you don't want to wait during a glue-up, you could use screws and be careful about not running the blade into the screws.
