Posting this for a friend. He has a SawStop ts. He has a dado set with thin shims for width adjustment. His problem is that the shims drop between the threads of the arbor and become mangled. If anyone else has this problem and solved it we are interested. There is insufficient clearance to put tape on the arbor threads. Jerry
Jerry, Tell him to just rotate them aft as he slides each on and adds blades, which will enable them to climb up as they move over. There isn't any difference in threads on SS than other brands, so I think this falls under the category of user error. He must be trying to slide a stack of thin ones which aren't perfectly aligned, making it seem like more of a problem than it really is.
It's kind of expensive, no, it's very expensive, but it saves a lot of time in setup. It's probably not the optimum solution for a small hobby shop, but if you are building lots of plywood boxes with different thickness of stock, it can save substantial time, especially in a pro cabinet shop.
Note that this is NOT a wobble dado. It cuts flat bottomed dados.
Pitch the shims. Put together enough chippers to come close to the desired width, cut all your dadoes undersize and either trim the shelves to fit or move the fence enough to get a good fit and make another pass with the dado set.
My set works the same way, and I just use caution when installing the next chipper to make sure the shim isn't down in the threads. I really like the shimmed set and the ability to get a dado just right for the thickness of plywood, so it's worth the extra effort to me to work with the shim's one downside.
Alternatively, a person could use a little tape to hold the ship up to the already installed chipper I think.
