Speaking of Delta.......Chance to buy a Unisaw
There is a 10" Left Tilt Delta Unisaw coming up on a freight auction. What's with left tilt? Somebody said they were dangerous???? What is the saw worth? Assuming good condition.
Re: Speaking of Delta.......Chance to buy a Unisaw
Left Right
is all about your preference. Lefties will tell you the right-tilt is more dangerous because the bevel'd piece can get caught between blade and fence. Righties will tell you the blade's easier to contact on a left tilt.
Comes down to personal preference.
Used Uni probably worth $1,500 with fence and long board in good shape.
PS
They'll all tell you theirs "cuts better/cleaner"
It can happen
Gary Smyth
Place me firmly in the left tilt camp. I have a right tilt. Cut off had a power assist and as luck would have it went thirty feet across the room and hit a chest right in the exact wrong spot. The projectile hit right at the rabbet awaiting the back indented and cracked the side. The chest is to be painted so the damage can be mitigated with some steam and injected glue, but a bummer none the less. Wouldn't have happened if a left tilt.
Re: Why do you think that you need a cabinet saw ?
I don't.....
I am thinking of buying it to resell. I have a forty year old Delta/Rockwell cabinet saw I am perfectly happy with. OTOH, if I can get a cabinet saw for half the price of a contractors saw, Why not? Part of it is auction fever.....the hunt is on.
It will be interesting to see if the fence comes with the saw. Fairly often at freight auctions you get box 2 of 2 and not box 1. Then weeks later box 1 shows up. My friend bought a Bies fence at this auction a few weeks ago and resold it. Now I am wondering if that was the fence being shipped with this saw?????
If you have time on your hands check around for freight auctions in your area. You have to mill through a lot of chaff to get a little wheat, but if you take your time you can find some stuff worth having or reselling. I watched a guy buy a $20,000+ metal lathe for less than $1000 and resell it before he picked it up for $7500. Of course, there was some "overhead". His trailer was not up to the task and the lathe crushed it right down to the ground. Totally demolished. Added to the cosmetic damage on the lathe also. (He asked me why I did not bid. Told him it was too heavy for me to try to move. Maybe next time he will listen. No)
Or
simply because he wants one.
Arg! Arg!
Need, after all, may have little to do with it outside of the commercial context.
That's it, right there....
John in NM
"OTOH, if I can get a cabinet saw for half the price of a contractors saw, Why not?"
That's the whole reason for the popularity of cabinet saws. If we all had to pay $2k to $3k or whatever they cost now, it would be the rare and wealthy hobbyist who had one. Since there are fairly large numbers available used, for quite cheap, it becomes seen as a "must have" item and helps drive new sales to hobbyists as well.
I have a 1950's unisaw that I paid $500 for around 2002. If I'd not come across a reasonably good deal I'd still be using contractors saws. Nothing at all wrong with them, but I'll still take a heavier saw when I can get it for the same or less $$$
I wonder....
John in NM
If I was the only right tilt user who learned to move the fence over to the left of the blade when doing angled rips. That's why the fence rails go over there.... :D
It also makes it easy to stay out of the blade's way for a right handed user. No downside that I've ever seen.
Right there....
Good friend inherited a 1930's Unisaw (or prior model name), 1hp bullet motor and all. Motor was toasted and the fence was half gone.
Brought it into my garage and the mods began with a new 3hp Baldor motor and mag switch, some sheet metal work on the cabinet, a used Bies fence and rail, and a custom mobile base, then all repainted in Delta blue-gray. He put $600-700 into it, but learned some welding and flame cutting, sheet metal, and how to tune the beast. He's still a happy camper after 12 years.
Re: That's it, right there....
ChuckInND
I believe that they are still a rich mans saw. They aren't a necessary in a hobby shop, but maybe good for braging rights. And they certainly don't fit everyones shop situation. They are an industrial, stationary saw that are not meant to be moved around, so ideally you need a dedicated shop that has enough power run to the saw and whatever else you may have running at the same time. Such as lights, radio, air filtration machine, dust collector, furnace, air conditioner, etc. It's just a hobby, and for a lot of folks including myself, we have to spend our money wisely and buy just whats necessary. And I don't mean by buying junk either, such as Harbor Freight.
Re: Right there....
ChuckInND
He probably could of saved some money and bought a 1 1/2 hp or 2 hp motor instead of a 3 hp. It would of been more attractive to the next hobbyist when he puts it up for sale someday.
BTDT
Especially when cross-cutting a bevel, got a better cut with the "show edge" on top.
Only sometimes...
John in NM
A new out of the crate Unisaw is indeed a rich man's saw.
The one I have is not - it cost less than a new contractor's saw, and ran just fine on an electric dryer outlet that was in my garage. Welded up a mobile base out of scrap and splurged $60 for 4 nice casters from Woodcraft. With the new plug for the dryer outlet, the whole setup cost less than $600 and has worked fine in all three shops I've placed it in. As I recall, a 3hp contractor's saw cost around $900 or more at the time.
I understand that you do not like cabinet saws for reasons of your own, but given the numbers why on earth would I have bought a contractor's saw instead? Now if there had been a choice between a $500 unisaw and a $250 contractor's saw, then maybe. Only trouble is, whenever I saw contractor's saws for sale around that time, they were more like $450.
Too Much
modifications would have been needed with a smaller motor. The Baldor and mount fit the saw exactly with the triple-belt pulleys lined up plumb and co-planar.
May be just my view but I much prefer the cut quality of a full-kerf blade, especially when doing long rips in hardwood and cross-cutting. The cut quality on the LS-1211 was highly improved when I went to a full-kerf blade.
Not insulting anyone's WW-II, mind you, but 3hp has its advantages. It's also nice to be able to keep the feed rate up so as to not burn the cut, especially in cherry.
Re: I don't.....
ChuckInND
I think that you need to consider that the market is really soft now, and that Delta has a really bad reputation right now. You may sit on it for awhile and still not get what you want for it.
William Duffield
a rich mans saw
When I bought my cabinet saw, it was the only viable choice. It was the only saw that had the required features, and it was not available on the used market. A poor man can no more afford to lose fingers than a rich man. It would cost more to have them reattached than all the tools and machinery in your shop, or mine. The difference in insurance premiums for a pro shop is a lot more than the difference in price between a jobsite saw and a cabinet saw.
I wore out a Delta contractor's saw, to the extent that it was no longer practical to use it to raise panels or cut miters.
OTOH, I know hobbyist woodworkers who use no power tools at all in their shops. I have no AC in my shop, and no longer use my furnace, which didn't use any electricity. When I moved into the shop, it was necessary to turn everything else in the shop off just to start the contractor's saw without blowing the fuse. After it was started, I could turn other stuff back on.
With recent developments in LED lighting, the power requirements of shop lighting have been substantially reduced.
I have no problem moving my industrial cabinet saw around my shop. With its fence and mobile base, it weighs about 800 lbs. and yet, I can translate and rotate it in any direction with one foot followed by one hand, until I run out of room.
Not all hobbyists build on the same scale as the things you build. As an extreme example, I know a guy who built a schooner in a shop about half the size of my shop. OTOH, I know hobbyist woodworkers who build only 1/10 or 1/12 scale models of furniture or of woodworking tools. And luthiers, carvers, turners, etc., have totally different sets of tool requirements.
There are lots of very passionate woodworkers who would be very offended if you told them that what they do is just a hobby.
Re: It can happen
John C Lucas
I simply move my fence to the left of the blade when doing tilt cuts. Eliminates the problem
ChuckInND
( When I bought my cabinet saw, it was the only viable choice. It was the only saw that had the required features, and it was not available on the used market. A poor man can no more afford to lose fingers than a rich man. It would cost more to have them reattached than all the tools and machinery in your shop, or mine. The difference in insurance premiums for a pro shop is a lot more than the difference in price between a jobsite saw and a cabinet saw.)
Which required features are you talking about that a cabinet saw has that a contractors saw doesn't ? And what does fingers have to do with it unless your talking about a SawStop ? Which is a totally different discussion. ( I wore out a Delta contractor's saw, to the extent that it was no longer practical to use it to raise panels or cut miters.)
Most people use a miter saw to cut miters.
( When I moved into the shop, it was necessary to turn everything else in the shop off just to start the contractor's saw without blowing the fuse. After it was started, I could turn other stuff back on. )
Thats more then likely how you wore the saw motor out, not enough power going to the saw. I had the same problem until I upgraded the electrical in my shop. Never had the problem since. I think that it's a common mistake that people make with contractors saws, then complain about the power, or they are cabinet saw pushers just bashing the contractors saw. A lot of that goes on too.
( Not all hobbyists build on the same scale as the things you build. As an extreme example, I know a guy who built a schooner in a shop about half the size of my shop. OTOH, I know hobbyist woodworkers who build only 1/10 or 1/12 scale models of furniture or of woodworking tools. )
I've had a Contractors saw since 1995 when I bought it new, It has seen a lot of use over those 21 years, and it's still going strong.
Is new Delta making parts for new Delta?
If you buy new delta stuff can you get parts?
Saw
Stop is what William uses, Chuck, and let's not get into another bru-ha-ha on the topic. Some love it, some hate it, others have their opinions. Done.
I am curious, however. You have repeatedly expressed your strong opinion to the effect that cabinet saws are a waste of money outside of the industrial context, and you seem ready to criticize anyone who happens to own one.
I understand that tool snobs are everywhere, and there is no shortage of people who will gauge a woodworker by the cost of the tools he owns. I suspect this may be a symptom of "small hand-size", but its not restricted to woodworking by any means.
I must note that I've never, ever seen anyone on this forum or good old Badger Pond make a derogatory comment about contractor-style table saws, and your posts seem more than a bit on the defensive side when it comes to having and using them to do good work. Have you been trash-talked because you either prefer or have financial resources that "limit" you to this class of tools? If so and you hang around here on WC, you'll find just the opposite attitude from WC members. Folks here are far less impressed with what you own than with what you make with what you have. The poor workman almost always blames his tools, and as Don Geiger was quoted "We're all just one tool away from greatness."
I've used a bunch of table saws, from bench-tops to job-sites to contractors to cabinets. Each has its place and, given the skill of the operator, each will do quality work or screw up an equal amount of valuable wood. I have contractor friends who can do highly precise work "in the field" with a job-site/bench top 10" saw. They don't hesitate, however, to stop by my place if they need something special milled or some gnarly hunk of highly figured stuff tamed. It's also a standing joke among us that I'm perfectly willing to pull out a micrometer to check if thickness matches.
If someone here has the good fortune to have disposable income to spend $4K on a table saw or any other high-end tool, that's great and hopefully it gives him or her pleasure to use. Doesn't mean that they can cut a better line than I can with a less expensive machine. I've made a lot of furniture over the years with much cheaper saws than your Delta contractor, and the stuff is still being used.
William Duffield
We're discussing essential features, and for me the SawStop technology and a riving knife are essential, just like seat belts, air bags, anti-lock brakes, traction control, radial tires, crumple zones and pollution control systems are essential features for an automobile. Depending on your application, a GPS mapping application may also be an essential feature, especially in New Jersey.
Yes, you can get flesh detection and braking technology on a contractor saw, or even a jobsite saw now, but you couldn't when that feature became essential on a cabinet saw.
I am not disparaging contractors saws in general. I've built lots of furniture, kitchen cabinets and even work benches using contractors saws. But the one I owned was junk, and it wasn't from Harbor Freight. It was not the motor that wore out, it was the trunnion lifting and tilting mechanisms, due to excessive vibrations of cheap, cast components. If a SawStop contractor's saw had been available at the time (about the same time you bought yours) I would have bought it instead, and I would still be using it. I have complete confidence it would still be working accurately today.
It was the starting current that blew the fuse. As long as I could get it started, and didn't try to rip a lot of 8/4 oak and didn't repeatedly stop it and start it, I knew I wasn't harming the motor. An electrical fire was, however, a real concern. I also replaced the electrical system in my shop as soon as I could get an electrician out to put in a 100 amp panel. The only time I've tripped a breaker since is when I stupidly tried to run the shopvac and a lunchbox planer simultaneously on the same circuit.
I've never built anything in a shop with a chop saw. I don't and won't own one, because they are dangerous. To put that another way, the risk is too great for me to accept. Everything it will do, I have at least one other way to do efficiently in my shop. For cutting miters, the table saw has an accurate (INCRA) miter fence and a miter sled, and I have a Stanley/Disston miter box.
I do have a radial arm saw, and I know it is dangerous. I have very strict rules about who uses it (me.), when it is used (when there is no one else and no other distractions in the shop, how it is used and what it is used for (breaking down rough lumber).
Re: Saw
ChuckInND
Mark, yes, in just about all the forums I've heard quite a bit of Contractors saw nit picking, followed by cabinet saw praising. I've also heard a lot of HF dust collection praising, more then I care to hear about both. I'd call it nothing short of a brainwashing sales pitch. It gets REALLY OLD. William, lets think about your earlier statement where you said ( When I moved into the shop, it was necessary to turn everything else in the shop off just to start the contractor's saw without blowing the fuse. After it was started, I could turn other stuff back on. ) When you start the saw it's under a load for a short period. While your cutting, and depending on what your cutting, your under a load also. So please explain to me why it is ok to turn everything else back on before cutting something. I never had a problem at startup like you did, the problem was only when cutting something thick. I'm sorry, but in my opinion what you were doing was hard on the motor. What brand of contractors saw did you have ? As far as SawStop goes, there are a lot of things in a wood shop that will take a bite out of you. I seen a kid in junior high just about open his stomach up with a drill press. So where would it stop ? If every machine in the shop was loaded with that technology very few could afford to equip their shops, and even then there is no guarantee that people wouldn't be hurt by something else in the shop. I've always thought that if people can't have enough respect for what a machine can do to them, or they don't have the time to pay attention to what they are doing, then they don't belong in a shop. And if they do get hurt in a shop, they more then likely have no one else to blame but themselves.
Why? Because...
Clifton C
In 2000 I bought a garage with a detached house. I bought my 3hp delta cabinet saw in 2001. I could not afford it. PBJ's for a month of Sundays...In counting up the delta saws in the various shops I had worked in I came up with seven, all good except for one that was direct drive. My buddy John (RIP) used to say "buy once, cry once" so I did. More saw then I need/deserve? Absolutely. I've buried a blade cutting 12/4 oak and that saw says "And, what else you want me to do?" I've also abused it with 1/2 inch aluminum plate, same thing, "what else you want?" But it sure is nice to have tools that don't complain...I guess my priority, way back then was a nice table saw, not a T bone steak. Over the years I've added a few more tools to the collection (So close to greatness, Don G...So close...) The problem I have now, is I have no one to blame but myself for shoddy workmanship, as I cannot blame the machines. Cabinet/contractors saw, blow boaters/stink potters, gouges vs scrapers, tomatoes, tomaatoes? ? ? It's just me in my little shop, having a good time or bad, and sometimes it's bad. I choose good. . And for me, that's what counts.
cc
There
ain't no sucha thang as idiot proof, Chuck. Good people keep trying; more power to'em, especially if they've got the guts to keep trying and looking for alternative ways to succeed. Beyond that, good and skilled people make mistakes, loose concentration or get distracted and WHAMBO! they get hurt. They are, after all, merely human. It happens in shops, restaurants, warehouses, garages, and in virtually any place, job or activity you can name. Accusing the injured with being at fault, or stupid, or imposing blame is all to easy for the observer, and mostly useless unless, perhaps, it makes the observer feel superior.
Where does using technology to make stuff safer stop? Hopefully never and nowhere. I suggest that your framing the issue as a function of financial cost is short-sighted. Ask the guy who had his arm ripped off by the tree shredder if that lost limb was worth the cost of putting a dead-man bar on the intake.
