I have several left over 16 inch drawer slides and want to use them for 22 inch drawers. They are full extension. What would be the best way to mount them? I would like the full extension but that isn't an absolute.
Stuart - I am no expert, but it seems like full extension of 16" drawer slides is only going to give you about 16" of extension. So I am unsure what you mean by 'full extension" but I would think that 16" slides on a 22" drawer would at best be more like 3/4 extension slides (or whatever 16/22 is). But then maybe I misunderstood you.
As to mounting, can you not mount according to the manufacturer's instructions? I would think the slides would mount normally (from front edge back), even though they do not go all the way to the back of the drawer.
That means you will only get 16" of extension, Stuart. If you need to have better access to the last 6" of your drawer, I'd go with properly sized slides.
If you mount both components towards the front (front of the drawer, front of the case) there will be a lot less strain on the slides and their mounting screws than if you mount them both towards the back. They will be more visible. What you don't want to do is mount one half towards the front and the other half towards the back because that would severely limit their travel.
These considerations are in addition to Henry's good advise.
Why shorten them? Just put in a false back at the 16" distance.
Even better, build boxes that fit in the back of the drawers, whose fronts look like a drawer back. Everybody loves hidden drawers.
There is another alternative, which I have used in my shop to support a drafting table: tandem drawer slides. The drafting table is installed below my bench top. When put away, the front of it must be further inset than my top stretcher, on which a deadman slides. It must also extend beyond full extension, so the back of the table top clears the front of the bench when I pull it out. I then tilt it on hinges attached to the front of the table top and the front of its undercarriage, push it back a few inches and set the back of the drafting table top on top of the bench.This gives me a sloped surface appropriate for drafting, and still provides clearance behind me when I'm standing at the table.
For a drawer, you would require two pairs of slides, each at least half as long as your desired extension, and you would lose as much as 2" (and at least one inch) of width.
These drawers are going to be made from scrap plywood and go in cheap Big Box base cabinet that currently has a drawer on top and door on the bottom. They will be used to hold sand paper in little cubbies and maybe some of the gouges I don't use very often. Maybe someday I'll build something nice but this not it.
I go to a wholesale supplier that sells to my friend in the cabinet business and buy full extension runners for about $4 a drawer. Pretty bare bones. Have ask them for the screws. Nice runners. Look around.
