Questions On Rotex 150 Festool Sander
I mentioned recently that I got some Festool tools at an auction. I do not have one for the Festool Vacs or even the hose for one. I rigged a way to connect my Cheap shop vac to the router and track saw. Not perfect, but works well enough. I was surprised to find the connection for the Rotex sander to be completely different. A smaller port with two rings around it. The others are larger and I insert a tapered Wand" I cut off to be the correct diameter.
Looking on the Internet (Youtube) it appears the "proper" hose has a soft robber connector that slips over the spout and rings.
Anybody have one and willing to explain? Anybody got a good idea how to do this cheaply? (Anybody explain why they use two different methods?) Anybody got a good web site for this.
Re: Questions On Rotex 150 Festool Sander
William Duffield
I can help. I have Festool Rotex sanders, a track saw, Festool vacs and a Ridgid Shop-vac. The same hose end fits all the Festool tools. The tools like the routers, chop saw (Kapex) and track saws, which create more chips, can also be used with a larger diameter hose. The hose end goes outside the connectors on the smaller tools, but inside the connecters on the larger tools.
Festool sells hose ends as a separate replacement part that will fit each of their hoses, but a different hose end for each different diameter hose (27 mm, 36mm and 50 mm).
What I would do is take your shop-vac hose in to your nearest Festool dealer in Glen Allen and find the hose end that most closely fits it. Attach it with some duct tape, or chewing gum and bailing wire, Bondo, hot melt glue, etc. to your shop vac hose or one of its nozzles.
Alternately, I have a spare hose end connector that fits the 27 mm Festool hose, that I could mail to you. I needed to connect two Festool hoses end to end, so I bought the hose end adaptor that connects to the vac and put it on the end of one of my hoses, and then used your cut off tapered shop vac tube trick to connect the hoses end to end. That way, I don't have to drag the Festool vac all around the shop and deal with its hose. Instead, I have a long boom for the hoses, and I can do all my tool swapping with connections at the end of the umbilical. I disconnect the vac hose and the power cord from one tool, connect them both to the next tool at the stack of systainers, and turn on the tool. That automatically turns on the vac. When I'm done with the tool and turn it off, the vac automatically delays a few seconds to complete removal of the dust from the tool and the hose, and then shuts off. I use the same power cord, velcro'ed to the hose for all my Festools, and never need to go find the vac or the wall outlet to connect or disconnect power cords or vac hoses.
You are going to have another problem with that 6 hp (LOL!) shop-vac. It sucks too much, at least until the filter clogs up. Festool sanders work much better with a very limited amount of suction. Your shop-vac will pull the sander down hard onto whatever it is you are trying to sand, resulting in overheating of the abrasive disks and h&l interface, very ineffectively remove the dust, prematurely wearing out the abrasives, and leaving totally unnecessary swirl marks. Unless your shop-vac has a variable speed control that you can adjust to keep the sander just floating over the work, you will need to kludge a bleed valve between the tool and the vac to decrease the suction in a controlled manner. This feature is built in to all the Festool vacs.
Another effective feature you will discover with the Rotex sanders is that they have an air pump that pushes air down through a hole in the middle of the abrasive pad and out towards the edges, carrying all the dust with it, to be picked up by more holes in the abrasive and pad and carried to the vac. The holes around the circumference of the abrasives are much closer to the edge than other sanders (and there are more of them), where they much more effectively collect the dust, instead of slinging it all over the room and into your face. The air pump also helps the sander to glide over the surface of your work.
Thank you William, very nice of you to....
take the time to provide such a detailed answer.
Being new to the world of Festool, whoda thunk less suction would be better on a sander? I kinda sorta knew it from watching Youtube, but now that you explained it, I understand it better.
I'm trying to convince myself to buy one of the dust extractors but I'm still overwhelmed by the price. Now it seems one of the smaller ones might be the ticket. I have tiny shop blues and I doubt any of the Festools will see much use on any house I work on. OTOH, I am skeptical of the one in a Systainer. Too cute by half.
Thanks again.
John in NM
I do the same as you with whatever shop vac I have at the moment, hook it up to the tools that have dust ports.
I've found the flexible rubber plumbing fittings with hose clamps to be very useful for this. They're available in a variety of sizes, neck down to other sizes, and are flexible enough to squeeze onto a port that is a little big or a little small. That may or may not help you with the rotex though, I've not seen the dust collection parts for one of those. My Festool jig saw does have some kind of snap in dust duct - could be a part like that is missing as well.
William Duffield
The dust duct is permanently attached on all the Festool sanders (except maybe the drywall sander, which I'm not familiar with).
The power connection and the dust connection are the same on the sanders and the jig saw.
John in NM
Hmmm... I'll have to go look at that jig saw again. Its one of the tools I don't usually hook up to the vac, so I've not paid a lot of attention to the dust port on it.
I really liked their older one where the dust port ran through the body of the saw - this one it hangs out the back of the base plate and looks kinda awkward to use. Unfortunately, that older one I had got stolen, and I didn't get around to replacing it with another Festool until they'd changed that port (and gone with keyless blade holders and better motor - so I'm not really complaining about it :D )
William Duffield
I usually don't hook my Carvex up to the vac either. I would if I were using it in the house, but the decreased maneuverability is a disadvantage in the shop, even with the flexible Festool hoses and my overhead boom.
Note that Festool has blades especially designed for the Carvex jigsaw. The older Trion blades and Bosch blades can overheat, especially when turning tight curves and if the guides are not properly adjusted.
That may explain it...
John in NM
I have a PS300 rather than a Carvex.
Yeah...
John in NM
The vacuum schnozzle on mine is removable. But more to the point - that's not Barry's problem since you say the Rotex works like your Carvex with a non-removable port.
Those plumber's cheat nozzles are still worth looking at though.
This kind of thing:
Good thinking.....I just went to..
WoodCraft, the local Festool dealer and they did not have either of the parts they thought might work.
I will hit the plumbing supply aisle.
Thanks
Thanks and an Oh Pooo!!!
I kluged together a connection and used the sander for a few minutes.
As I said earlier I bought three tools at an auction. Did not get the manuals and few of the odd parts. I got a "75" track saw, a 1400 router and this Rotex 150 sander. The sander is the only one that appears to have more than an hour of use and the pad was beginning to delaminate and fail. After a few minutes of use, the pad failed and flew away. Local Woodcraft (Festool dealer) has one but they are 25 miles away and I did not have time to get there before they closed for the day. I will get it tomorrow.
Anybody tried to glue a pad back together? So far, the only thing I don't like about these tools is the price. $46 bucks for a sander pad bites.
Got any 3m 77?
John in NM
That might do for gluing the pad back together. Its a foam safe spray adhesive, spray both sides, let it dry, then stick them together.
I found out today that "foam safe" does not include styrofoam (didn't really think it would, but had to check). Should be fine on a sander pad though, and if not, you already needed another right? :D
Re: Got any 3m 77?
Too late. I soaked both sides with CA and put them together. Did not think of 3M 77. Had some of that too. I have glued 2 and 3" pads I use for sanding bowls with CA and it seemed to work. I can't remember doing one that had can be completely failed but repaired some that were cracking. I will see if the CA works in the morning.
My theory is you can't break something that is already broken. Might as well take a whack at it. I will get a new one tomorrow. If the glued one works I will use it and keep the new one as a spare.
Re: Thanks and an Oh Pooo!!!
Jesse Cloud
You can read or download the RO-150 sander manual at http://www.festoolusa.com/media/pdf/Rotex.pdf
This manual is for the current version, which you may not have - but most stuff will still be accurate. The RO series is actually a very flexible machine which runs in two modes: random orbit and rotary. It will vary in aggressiveness all the way from being a great buffer to a pretty close relative to an angle grinder.
The manual is definitely worth a read. BTW, manuals for all the tools are on the website cited above.
Gluing the pad back together appears to have worked, but not perfectly. I tried it this morning and it appears to be holding up, but it seems to be hard to handle. Wants to dance around. I had a bunch of crumbs of foam and I am assuming the pad is not as flat and consistent as it should be.
Thanks for the lead on the Manual. I will be looking at that. And I am on my way this afternoon to get a replacement pad. I need to check out the mode switch on the new one at the store. When I switched mine to random orbit, the switch seems to have fallen further into the machine that I expected. I am on Grandfather duty this week and did not have the time to fiddle with it.
William Duffield
Getting used to Rotex sanders takes some time and practice. They do tend to jump around if you don't have the speed right for the wood and the abrasive grit, or don't have the suction set properly or even if you are using the wrong grip. I find the RO125 (5") much more difficult to control than the RO150 (6").
What you describe sounds like normal operation of the mode switch.
The dust collector part I offered you is the same as the part number Jim provided in his link. I didn't think to look it up because it didn't occur to me that it was available separately from the hose. I should have known because the part I replaced it with is available, and it's just a different diameter, but performs the same basic function.
