perfect TS sled fence, no measurement
eliot feldman
I've following Mr. Ng on setting up my table saw sled back fence as close to perpendicular to the blade as possible. He, like others, advocates the five cut method. It works rather well, but it's not so simple as it looks because one makes tiny caliper-measurement errors, and other tiny errors are introduced by just clamping and inserting screws in the final steps. So, if you're as clumsy as I am, you end up going back and forth between setting the fence too low and too high.
Here's my new method, which doesn't require any of that, and you should get a perfect set up with just one cut.
Just square up the fence as carefully as you can with a good square. Then glue up a sufficient number of boards so that their thickness is the height of the fence. The length of the resulting block has to be equal to the length of the fence, and the width has to be enough to register squarely on the fence. You do have to get a perfect right angle between one straight long side and a straight short side. Obviously you don't want to do that with your (still) imperfect sled.
Now place the short side on your sled fence and make a long cut along the long side of this board so that the cut off is fairly thin, perhaps half of an inch; it really doesn't matter. This cut off will look as if it has even thickness, but, almost certainly, it is actually a long thin wedge whose width is the height of your sled fence and length as long as your fence. You will have to measure just to determine which end o this wedge is thicker; the actual amount of difference doesn't matter -- just which end is thicker. (So I don't count this as a measurement.)
Now just glue it to the front of your fence in the obvious orientation to correct for the lack of perfect squareness. For example, if the far side of the wedge is the thicker one, that means the left side of your sled is set too high. So you would glue the wedge with the thicker end to the right. ( I am assuming that your cut was on the right side of your block.)
If you use thin CA glue, that should not mess anything up.
Re: perfect TS sled fence, no measurement
Mike Circo
Sounds intriguing... but you lost me.
Pictures? Or better explanation?
eliot feldman
I've never been good with getting pictures on this site.
Basically, you're just compensating for the sled being a tiny bit off square by gluing in a wedge along the front edge of the sled fence that exactly compensates for the error.
Please tell me what part you find confusing.
People are going to ding me anyway because you do need a perfectly square right angle in the board you cut the wedge from; and, theoretically, if you can do that, you can get the sled right in the first place. But I contend that any good woodworker ought to be able -- without a lot of fuss -- to cut a not too wide board along ONE straight edge and cut a perfect right angle to that.
eliot feldman
Obviously, nobody is getting what I trying to convey. It won't make sense to anyone who hasn't built a TS sled and used the five cut method to get it to cut very square. See Mr. Ng's video on the five cut method.
My point is that making the five cuts, measuring the A-B difference, doing the arithmetic, and then fixing the fence with screws and using feeler gauges, and then readjusting the fence and doing the five cut method again, etc, etc, while a fine idea, is full of subtle possibilities for tiny errors that easily throw off such a delicate adjustment.
My method requires only that you can cut one straight board the length of your sled-- not very wide-- and cut a perfect right angle to it ( away from your sled) --- perhaps using a Japanese hand method, for example. Then after that, there is NO measurement necessary!
If anyone is interested, I can explain it further.
Jason in OC
I've also been flummoxed by how to make accurate microadjustments to set the fence, and then not throw everything off when you screw it down. I think I understand what you're saying, so let me try another description.
Image the sled fence is some amount off square to the blade, say 2deg. Now put a block of wood on the sled. The face against the fence and the face about to be cut must be square to each other. Make the cut. The offcut will have the same error angle (2deg) as the fence. Glue the offcut to the fence such that the two angles cancel each other out. You now have a fence that is square to the blade.
I haven't built a sled but it makes sense to me - instead of adjusting the sled fence you are correcting the error by shimming the sled fence. Assuming you do start out with a perfect 90-deg angle on your test board, the wedge cut with the TS will be the angle of the error.
Making the correction wedge tall enough for a tall sled fence might be an effort.
I've been designing a sled in my head with a micro-adjustment on the fence and a way to lock it with no movement.
eliot feldman
Yes! You and John have it exactly right. And John is right about some difficulty in gluing up a board -- unless you already have one -- that's the height of the fence. The key issue is not to have to measure and screw things down.
