Re: Offcuts jamming
will occur if the operator leaves his smarts outside the shop door. The "under fence" area needs to be cleared after several cuts. Simply turn off the saw and shove a board through between the main fence and the stopped blade. The one I made is about 4" wide as my cut-offs were never wider than an inch or so. Heavier stock gets cut off on the band saw first. I also did not depend on just a glue joint and reinforced the "T" with 4 screws.
I've used the "L" fence on a number of pieces and it works as a very safe alternative to a taper jig, especially where you're tapering thicker leg stock.
Small Tips:
Put "slick strip" tape or a piece of HDPE on the working edge of the fence so the guide piece slides smoothly.
Double-faced carpet tape is essential unless you're going to fix your guide piece with screws. I seem to remember the mag article using sticky-back sandpaper. I would never depend on mere friction to hold the guide piece in position.
