I'm looking to make a bed for a friend who likes Mid Century Modern. It will go between two endtables made in that style from teak. The end tables were recently refinished and we plan to ask the person who did that to finish the bed to match.
My question is that since teak seems to be very expensive, is there another wood with similar grain structure that I could substitute?
You might consider rift sawn white oak, it was used for mid century modern. But would need to be dyed. Mahogany or rift walnut may be considered, but the mahogany would be easier to color match.
those are all open pore woods. The Teak that i have is very close pore more like Cherry than Oak. Cherry doesn't have the close grain lines like the sample of Teak that I have. It is much closer in color and appearance but of course will darken with age. I don't know if Teak darkens or not.
Only thing I've ever seen that looked just like teak was some ancient Chinese elm - not much help at all.
Teak can also be highly variable in density, depending (I suspect) on whether it's plantation grown or forest grown. Some flat sawn teak I've seen looked a bit like walnut in grain, but then there's that funny greenish, light brown color. Other teak seems to look much like some of the crummier examples of African mahogany, again but for the color.
I think I would start by looking at the tables to see which kind of grain might match, then plan on bleaching it and matching the color back. Probably won't help to have the refinisher do the work - it's going to take a different schedule and a lot of experimentation to match it.
I think I would suggest to them not trying to match - but then I've never had much luck with it, the boss had never budgeted sufficient time for it and I never was able to get a result I liked.
I still have some teak scraps if you need some for comparison - like if the tables you're needing to match are not local for example. I need to come in to town and have lunch with you one of these days anyway - been since December right?
the manufacturers of high end garden furniture or boat restorers? "You Tube" and "Pinterest" can get you to manufacturers and/or boat restorers. The sources may not only get you an opinion quickly for an alternative, but perhaps a source that may reduce the price of the teak if there is no good alternate.
Even in the properties. Teak is fairly light weight and decay resistant, which is one of the reasons it is so costly. There aren't many that look as good, which makes it desirable for higher up on boats where the center of gravity needs to be kept low, while being exposed to the worse elements of weather. Sassafras is light, durable, about the same density, and easier to work, due to not having the high silica content which dulls your tool very quickly.
Of course you can't always find Sassafras, so a more readily attainable substitute might be Birch. It is light enough, that it could be stained.
A much harder wood, with about the same color value would be Black Locust, which isn't easy to find around here, but might be over in Tennessee.
Beech is not too expensive around here, nor Hickory, if the medullar rays of W Oak are objectionable.
Sassafras, at least what I cut here, doesn't look much like teak, at least what teak I've seen which hasn't been much. That's too many "at least"s! The question is what does the furniture to be matched look like?
I found this note about teak on the Wood Database: "Much like the many names and knockoffs of Mahogany, the moniker “Teak” has been affixed and assigned to a number of different woods seeking acclaim. The usual procedure is to take a wood bearing any degree of resemblance to Teak and insert a geographical location in front of the name. For instance, Cumaru is sometimes referred to as Brazilian Teak, while Rhodesian Teak bears little botanical relation to real Teak—Tectona grandis. The name Burmese Teak, however, does refer to genuine Teak."
Some of the black locust I've cut does look more like the teak I've seen but I have no idea where to get enough for a bed. I mostly cut turning blanks from mine.
The Teak I used was fairly heavy. Heavier than Ash or Birch, not as heavy as Ebony. I don't have specifics, but that statement doesn't match with my experience. My understanding is weather resistance was the primary reason for it's use on boats, that, and the fact that it can be finished exceptionally well. Weight - I'm open to correction.
Jesse, afrormosia (aka assamela, mohole, kokrodua, ayin, egbi, ejen) is a west African teak look-alike with similar properties and uses*. We have 21+ year old deck furniture made from the stuff that is still going strong. I don't have any other knowledge about its availability, pricing, sustainable harvesting etc, etc. Woodfinder has several sources for it. Jim
