Faded furniture
Faded furniture
Faded furniture
Peter Rad
Hi there,
I was reading your write up about tung oil, as it was recommended to me as a fix for wood exposed to light.
The problem I have, is that the fading is rendering as a sudden line where a door was left open over the area affected. (so half the panel is affected and half not - a hard line)
My question is: Do you think that tung oil will bring back a more even color finish if applied evenly to the whole of the panel, or would it need to be graduated on the affected side only?
I’m desperately trying to not sand and refinish these as it will greatly affect the authenticity of the piece.
Any advice you could offer would be most welcomed.
Re: Faded furniture
Re: Faded furniture
Keith Newton
I would say it is not likely to fix this. Also, have you ever heard the phrase, "A picture is worth a thousand words?"
Did I miss where you mention the species of the wood?
Re: Faded furniture
Re: Faded furniture
John in NM
Unfortunately, there is no fix short of refinishing. Fading comes from the UV in sunlight breaking down the chemicals that give the wood its color. The only solution is to sand off the faded wood and expose a fresh surface. About the only upside here is that the faded layer is very thin so it's doable with a quick strip, sand, and refinish.
About the best way to avoid this problem is to use a pigment stain when refinishing - those are the most colorfast. If you can choose a subtle stain, it won't be noticeable as stained, but you should also be able to avoid such a pronounced line of fading.
Re: Faded furniture
Re: Faded furniture
don stephan
Peter
Over time, sunlight can affect the color of wood and the color of dyes and stains, and some finishes will change color slightly with time (unknown if due to sunlight, oxygen, . . .)
If the piece has possible monetary value I would not suggest experimentation by anyone other than a skilled conservator.
Re: Faded furniture
"...authenticity of the piece"
Gary Smyth
What are you trying to keep authentic? Is it the design, the maker/owner, age? If you are considering refinishing then understand the patina will be affected no matter what you do except leave it alone. On select pieces it is better to do that than to do something cosmetic and not reversible.
A majority of furniture properly refinished will not lose value unless it is so rare as to worthy of a comparable items value supported by documentation. Without rarity and documentation the very high percentage of what is out there is better off refinished by someone who knows both his/her stuff and the market. Even the top auction houses do some "refinishing" to enhance value before getting to the block but they also closely detail what they have done. If you have a unique find, spend the money for an appraisal and let that value determine if refinishing will do harm or benefit.
Lastly, being authentic is no guarantee of value. If there are hundreds of the item out there then straightforward refinishing may serve better for resale provided of course it is made to appear better that the remainder of what is available. As an example. I used to collect very specialized slide rules. After amassing many, what I eventually found out was that even the most complex of the rules very likely was made by multiple companies, in quantities in the hundreds or thousands for over a decade or more. All were authentic, quite expensive at the time, but most were placed in more than a few engineer's desk, unused for fifty years. They were authentic, but even without the slightest flaw they had little value because there were so many others out there.
If you are able. show us what you are trying to preserve.
Re: Faded furniture
Send me the pictures
Good response, Gary. Peter can send me the photo of his piece if he's unable to grok out our uploading protocol, and I'll upload it for him.
A couple side notes, which may or may not be germane to this particular piece:
First, I don't know how any long oil (tung, linseed, other) might be a fix for wood exposed to light; and second, some of the most valuable antiques in the world are routinely repaired, albeit expertly, with techniques involving patches, replacement parts, detailed surface prep, staining and finishing. Further, the decision on the staining regime should rest on the authenticity of the look that is appropriate for this piece, which would likely include several layered wipe-downs with dyes, possibly pigments (though I'd think not) and maybe other tricks to mimic the aged look you're trying to achieve. Depending on the market for your particular piece, a bit of expert repair work will probably enhance the value rather than detract from it, especially if it is a utilitarian piece.
Re: Faded furniture
Is it the finish ?
Yonak
It's possible that the finish itself has been clouded by the sunlight, making it look faded, and the wood not discoloured at all. I have a cherry table that takes stark sunlight at times during the day and looks bleached where the sun hits it. I thought it was the wood getting bleached but, from what I've learned at this site, cherry cannot bleach, only get darker, so that only leaves the finish as the culprit.
To see if the OP's issue is the finish, would anyone suggest wetting the surface with mineral spirits to see if the fading disappears ?
