Performax conveyor belt again
I bought a replacement belt form Woodcraft, in spite of thinking the one from Klingspor might be better and cheaper. I bought the previous one from Woodcraft and it worked for years and they were local and had it in stock.
I can not get it to track. I tried repeatedly. It always tracks toward the motor and won't stop. I turned it around. Same thing. I checked all the alignment. Everything seems level and true and square. Had friend who has a life time of experience setting up industrial equipment try and he could not get it either.
We checked the rollers. They appear straight and true. Not knowing what else to do, I ordered a replacement from Klingspor. Now we wait. And we will see.
The little bastard beat me. I would like to make it work just to even the score.
Re: Performax conveyor belt again
Call JET
They bought P-Max and will give you some help.
You said you checked alignment, etc. Hate to ask, but did you adjust the tracking according to the manual?
When the belt on my 22-44 didn't track correctly I tried adjusting according to the manual. That made it worse. So I tried the opposite of the manual's instructions. That worked. I read later that some manuals were printed wrong.
BTW, when I started adjusting the belt was too far towards one direction. Before making each adjustment, loosened the belt, counting the turns, slid the belt to the middle, unloosened the belt, then made my next adjustment try. Once I got it adjusted it stayed put. It's been fine for a couple of years now.
I'm going through the same thing right now. The directions in the manual are backwards. I used to work for Zerox and had to constantly adjust belts to get paper to feed correctly so I know what i'm doing when it comes to belt tracking. However I haven't been able to get my belt that I bought from Klingspor to track correctly. I have reduced the time it takes to track all the way to the edge but so far have not eliminated that tracking or for that matter made it track the other way.
I'm about to the point of taking some duct tape and wrapping it around the outfeed roller and build it up in the middle so that it has a high point in the middle. In theory it should track toward that high point of possibly stay there.
My best luck has been to not run it too tight
Dick Coers
Seems like it tracks better if it is what you would think is too loose. See if helps with a little more slack.
Now that sounds like a good idea. I wonder if just a very small increase in diameter in the middle would be enough. Rather than duct tape, how would some kind of spray-on coating work? First thing I thought of was the tough rubberized vehicle undercoating spray.
Or more permanent and riskier: chuck the roller up in the lathe and file the outer parts! Probably just need to shape one roller - on my knife sharpening machine one belt roller is domed and the other is flat.
If a belt used to track and quit, I wonder if it stretched in the middle.
That's funny.......
My friend bought a 4 X 24 porter Cable belt sander. Could not get it to track to save his life. Finally decided it should have some crown on the front roller. Added some duct tape and it worked fine. The whole experience ticked him off, so he packed it up and sent it back to Porter Cable with a letter explaining the roller needed to be crowned and that otherwise it would not track. They removed the tape and returned it to him with a letter explaining they had removed the tape. They later admitted they had not even checked to see if it would track. He gave up and turned the roller on a metal lathe and fixed it himself.
I grew up on a farm. We had lots of things that had belts. All the pulleys were crowned.
I actually tried some tape on the drive roller today, but it did not seem to help. I put it on the end away from the motor, thinking it would "climb" and track away from the motor.
This is a poor design.
I hope my experience with the Klingspor belt is better than yours.
Jim DeLaney, Austintown, Ohio
Check the belt itself. If it's shorter on one side than the other, it'll never track right. Even if one side is just a quarter inch shorter than the other, it won't track right.
I have checked it and its right as near as I can tell, I will recheck. I have also checked the rollers for diameter and to see if they are level/co-planer, straight, and anything else I can think of. I also turned the conveyor belt around and it acted the same in both directions. I'm flummoxed.
Did you try putting it in the middle of the roller, like an actual crown? I notice one edge of my belt (on the 22-44) looks a little loose. If yours is the same way a crown in the middle might track where one at the end might not. Just speculating.
