I am looking for a small router, say in the 1hp range, 1/4" collet, for smaller, hand-held projects. I currently have a 15 amp Makita and a 15 amp Hitachi, one table-mounted more or less full time, both 1/2" collets.
I've heard good things about a Bosch Colt, but the model that seems to be praiseworthy has been discontinued.
I have and liked a Bosch Colt. It replaced an older Bosch laminate trimmer I had that I liked as well. Then DeWalt came out with its little compact router with a plunge base. I bought it and haven't used the Colt since. DeWalt thought of everything Bosch didn't: a great plunge base (Bosch has since come out with a plunge base accessory for the Colt), a solid, easy depth adjustment, an LED light, great balance, easy bit changes and more. I now use this little 1/4" router for lots of things I was using my big Bosch for. It's the berries!
Ive been using a Dewalt trim router for 15 years or more to do inlays and indexed routing o. The lathe. A lot of miles on that thing. Still runs good but the bearings are making noise. Still its running great so ill.probably just replace the bearings instead of the whole unit
I agree with Hank on the DeWalt Compact Router. I'm not a big fan of DeWally, but I do like this router and use it often. Dust collection is lame, but I don't know of a small router that does a good job on that.
It is, however, considerably larger than the Colt, which I also use. If the footprint of the DW will fit in the project, I go for it over the Bosch.
I tried a Trend small router and didn't like it at all, depth setting was not stable.
If you are looking for a really small router, there are a number that provide bases for Dremels. Lee Valley and Stewart McDonald have good ones, but they are pretty much limited to inlay and detail work.
Replace them soon. As in as soon as they are noticeably noisy.
That noise you hear is vibration, and that vibration will (to quote a particularly rural friend of mine) "waller out" the aluminum pocket the bearing sits in. For ease of assembly, this pocket is not especially heavy walled and the bearing is not pressed in there very hard, so it doesn't take much at all to ruin that pocket.
The only modern tool I've had where you could successfully replace a motor bearing is my Hitachi slider. That one has an O-ring around the bearing and a very loose fit pocket. Pretty smart move by Hitachi.
I have a Colt (for many years) and have been very happy with it. No issues, works great, etc. I didn't realize they had changed models. I did buy the new base for it and a Pat Warner plate. Just watch the fingers as the bit window is quite large and it is easy to slip a finger in there! No, I haven't, but....
I've had a Porter Cable 1/4" trim router for a number of years but as you know I'm not using much power stuff any more. When I used it for quickie jobs, it was more than satisfactory. I bet I would still find a 1/4" round over bit still installed in the unit. If you come through this way I'd be happy to let you try it.
I suspect we have the same small porter cable, the one that was discontinued a few years ago the 310 model. Its funny in a way because it had been in production for 20 or 30 years and was the bench mark for trim routers to the point that most cabinet shots had several, one for each bit they used. It didn't have soft start or electronic speed control because those things aren't needed on a small trim router. heck the 310 didn't even list its hp rating, it just did its job.
When I needed a new one I handled all of them and bought a Bosch colt that I ended up returning and searched out a new old stock porter cable that I ended up paying more for. Its smaller more compact and robust feeling as well as being more precise in its adjustments.
From the reviews I've read of the new porter cable it is being compared to the Bosch colt and is not faring well. Too bad they didn't leave things alone.
Funny but after writing my reply to your question I looked for the little trim router and could not find it in the garage. My son has done some reorganizing to accommodate his fishing boat so I'll check with him. Gee, now I'll have to clean up my work bench.
