Hello; I have an early 70's Craftsman T.S. Over the years, I have made many upgrades to improve its performance (Biesemeyer fence, balanced pulleys, etc). The one thing that still bugs me is the low power, single speed stock motor. I'd like to go to a 220 v TEFC motor. Can anybody suggest a suitable replacement that would not require me to retrofit the mounding brackets on my old saw?
Beez fence hum,,,,,,, So you couldn't find happiness with the standard vice-grip pliers handle replacement? :>)
I haven't ever owned one of these, but do have an old Rockwell contractors saw with the motor hanging off the back, that I upgraded to a 2 hp Leeson open frame motor. I suspect that you will find, as I did, that the TEFC adds a couple of inches to the length of the housing, which isn't a problem if you always cut at 90º, but will be in the way above the table when tilted to 45º. The open motor wasn't a problem for over 30 years, and I confess to not being diligent about blowing it out regularly, so don't discount that option.
Yours is probably a left tilt, so the motor above the table would likely be behind the fence except when the fence if over a ways for sheet goods.
OH, and one other thing. I had to orient the pulley as close to the motor on the shaft as it would go, with the set-screws on the outer end, which allowed the motor to move down a bit more when tilted.
Another thing that helped, was that I drilled holes in a 1x2 to fit over the studs on the trunion, to hold the motor out a little ways. This settled down some of the bounce that would occur from the motor climbing the belt when under load.
A segmented belt also reduced the belt memory vibration too, but made it louder like off road tires on a truck. If this was my main saw, I'd try to find pulleys for a thinner multi-grooved belts, but in my shop with two better table saws, it only sees action as a job-site saw.
You may get lucky and find that Craftsman used a fairly universal motor mount - that was more common in the 1970's than it is now.
The big downside to motors these days is that they went and got really, really expensive a few years ago. A new 3 hp motor for my unisaw cost $550 when I bought it around 2012. A 1/3 hp Marathon furnace motor runs well over $100 - how far over depends on where you get it.
I'm not sure why you would want to change the speed. If you are wanting to slow down the peripheral speed, and increase the torque, reducing the blade diameter will get you that, like shifting your car into a lower gear.
Bill, you don't really tell us a lot about your saw. I've had a Delta 34-441 Contractors saw since I bought it new about 20 years ago or more. It has a 1 1/2 hp motor. For the first few years it seemed under powered, it would occasionally trip the breaker in the service panel in the wall when cutting something that was a challenge. After a few years of that I installed a couple 230 V circuits and switched the saw motor over to 230 V. Now I no longer have the tripping problem. When I asked the electrician about it, he said that switching the motor over to 230 V didn't really increase the HP much, it was just more efficient. The bottom line is that if I had it plugged into an appropriate 115 V circuit I would of been just fine. An inappropriate extension cord can play a part in it also.
