Festool Domino Questions
If you have a Domino, would you buy it again?
A 500 or a 700? Will the 700 do it all or does the 500 do some smaller things?
Would you buy the vac to go with it? Which one?
Looking at them on line, this is beginning to get into real money by the time you buy the tool, the cutters, the dominoes, and the vac. What about the various gadgets?
Tell me what you think.
Re: Festool Domino Questions
Jesse Cloud
I have both the 500 and the 700. If the shop burned down, I would buy both again. The 700 can use the smaller cutters, but you need to buy a gadget from Seneca Woodworking to make the smaller cutters fit. I have the Festool Vac, but a shopvac will work. I do like the HEPA filter, especially when working with sheet goods. I think the main difference in the Festool vacs is the size of the bag. So the issue is how often you want to empty/change the bag.
I have been doing mortise and tenon by hand and router for a long time, maybe a thousand or so of them, so I have the skills. What I don't have is the time. In that respect, the Domino is a game changer. The fit of the mortise and tenon is exceptional.
Personally, if I don't need a deep mortise I go for the 500. Its much lighter and you definitely feel the difference after a couple of dozen mortises. You will also feel the difference if you are carrying the tool up and down stairs.
Check out the Festool forum at festoolownersgroup.com Lot's of info on the domino and there's a classified section. Ever now and then you see used 500's for sale by folks who have upgraded to the 700.
Thanks!
Tony - Memphis
I've been conisdering the 500 as my next tool purchase. Hard to pull that trigger! I too have done many mortises (not as many as uou for sure) using routers and a Powermatic benchtop mortiser, but I can see where the 500 would really come in handy. Lately, I keep thinking of ways I would use it if I had it. So, maybe it is time! Thanks for the review.
Tony
GolfSteve in Calgary
I have the small domino and a Festool vacuum. I'd buy both again.
I don't use the Domino a lot, but when I do it works well and saves a lot of time.
I bought the vacuum because it's quiet. It's not a great vacuum if you want a wet/dry shop vac to pick up construction garbage, but it is a great vacuum if you want a small vacuum for general cleanup around your workbench, and for use as dust collection for your sander, router, domino, etc.
The vacuum bags do a wonderful job of collecting very fine dust. The bags are followed by HEPA filters. After years of collecting sanding dust, the original HEPA filters are still very clean.
The small diameter hose (about 1" dia.) supplied with the vacuum is great for connecting to your sander, etc., but is too small diameter for general cleaning. I bought a larger diameter hose (about 2"), and the larger hose greatly increases air flow and ability to suck up construction junk.
William Duffield
I have one of each. I bought the DF-500 well before the DF-700 was released. My 500 is one of the original ones with pin stops instead of the later, less effective, tilting toggles. (There was a patent problem with the original pins.) The 700 has redesigned pins that are much more effective than either model of 500. If I were doing it today, I would just buy the 700 and the adaptor (third party, http://www.senecawoodworking.com/products/rts-500-cutter-adapter-for-festool-df700) that allows you to use the smaller 500 bits and tenons with it.
You definitely need a vacuum connected to it to use either one. Without the vac, it clogs up after cutting one mortise.
The smallest Festool vac on wheels, the CT-Mini, is more than sufficient for running a Domino or any of their sanders. It is just as powerful as the larger vacs. It just has less dust holding capacity. I have both an older model CT-Mini and a CT-26. I haven't investigated the new CT-SYS (a vacuum in a Systainer), so I can't make any useful comments on it.
I use all the cutters, from 4 mm to 14 mm. I keep both beech and sipo (rot resistant African mahogany) dominos on hand. I guess I haven't sold the 500 yet, because I figure I might have a project that requires two different size tenons. I also have an assortment of the guides and gadgets, and have made good use of them. I even made a guide for doing adjustable shelf pins. I have found the RTS Engineering Self Centering Guide to be very useful, especially if you are making face frames. http://www.dominoguide.com
Of course, you could hook it up to any shop vac, but the Festool CTs have many advantages.
William Duffield
You will also want the larger hose if you plan to hook the CT up to a Kapex (SCMS).
William Duffield
Usually, I don't find the additional weight of the 700 a significant liability, and there are other factors about it that make it easier to use. I don't have much arthritis in my hands or carpel tunnel in my wrists YET, so that may change. Also, whenever possible, I use either Domino machine with the finished surface of the project down on the table saw, instead of using the Domino's fence for positioning, so I'm not lifting the machine as much as some people would. I've never used it up on a ladder, or even upstairs, for that matter, so Jesse's observations are probably more useful than mine for some situations.
Carrying any of the Festool CTs upstairs with a couple of systainers latched to the top, especially the SYS-5 that the 700 comes in, is a real challenge.
If you are not sure whether the 700 would be clumsy for you, walk into your nearest Woodcraft store (Glen Allen) and try them both out.
Dick Coers
I have the 500 and it has basically replaced my Multi-router stationary machine. I use it with a Fein vac. Any shop vac will work and you can get a device to turn on any vac with a power tool. Many of the Festool vacs are HUGE and really take up the room in a small shop. I've always thought the domino plates are too tight of fit. I'm concerned about a dry joint, so I bump them on 80 grit to have a better fit for more glue to stay on the faces.
North of the Border
DF 500 + any shop vac (HEPA filter, if possible) and save yourself $200 to $400.
Unless you build doors and very large tables, you don't need the DF700. Even if you build large doors and large tables, DF 500 can handle the job.
The Domino joiner has greatly improved my shop efficiency and the only tool in my shop that is more important than it is the tablesaw. 'nff said.
