Old 15" Porter Cable disk sander
Keith Newton
Last weekend, in the pile of old mostly lathe tool parts, I also picked up a 15" disk sander, which the parts were scattered, but I think I got most of. One thing that was missing was the motor cover, which had the wiring diagram. However, I found that online.
I was searching online for disk of that size, but google seems to think I made a mistake and looking for 5", so haven't found any that size. However, I do have some old heavy paper wide belts that I could cut my own from. I was curious though what is the best glue for these large disk?
I guess I ought to get on with wiring the motor up to see if that is still good before I waste any time on it though. I'm not so sure I even need this tool.
Re: Old 15" Porter Cable disk sander
William Duffield
Here's a page full of 15" floor sander discs on Klingspor's site.
that's as far as I looked, but I'm sure they have other varieties.
http://www.woodworkingshop.com/product/me93506/
I have that sander
Henry Higginbotham
Get it running. I think you'll find lots of uses for it.
Somewhere I've got a quart can of "latex disc adhesive." One application is good for several disc changes, which is nice since it's kind of a pain to remove. I'm sure it's available somewhere--Klingspor, maybe?
I haven't had to buy any abrasive, as I got three assorted rolls of 24" cloth-backed along with the sander. If you don't find some, I'll be happy to send a few pieces your way. It looks like I've got more than a lifetime supply.
The motor is repulsion-induction, so you may have to clean up the brushes and (flat) commutator. Mine had quite a bit of arcing before the clean-up.
I use 3M 77 spray adhesive
Robin Corell in Atascadero, CA
I get my discs from Snow & Galgiani in South San Francisco along with the glue I use. For wood I have a strong preference for paper backed Klingspor brand in 40grit. The glue I use is Master products disc cement made by Kindt Collins. Freeman Supply in Ohio is closer to you and will have these products as well.
The disc cement is is an amonia/water based product and is used just like contact cement. The difference between it and something like super 77 is that when it is time to change the disc it just peals off leaving no film or residue to clean up. FYI the PSA discs are notorious for delaminating and leaving bits of film and adhesive on the disc when its time to change them and super 77 must be cleaned with mineral spirits and then that must be cleaned with acetone.
If you will be using your sander for mostly metal then a cloth backed abrasive is prefered and super 77 is the way to go for adhering those. you can still use a paper backed disc for aluminum and some steel but you won't get the performance out of it that you will a cloth backed disc. Don't forget to load the paper with bees wax before sanding aluminum
The paper is usually a fraction of an inch larger than the disc. This allows you a bit of wiggle room when mounting it which is done with the table all the way lowered or removed. You place an edge barely in contact with the paper held at an ange to the disc then holding the paper opposite that spot you eye ball a spot on the disc at 90 degrees to the first contact point and bring the papar to meet that spot. try it dry a couple times and you will get the hang of it.
Once the disc is on I press on it with a block of wood and then reposition/replace the table. I turn the power on and as it is coming up to speed I make contact with a block of wood near the center and bring it to the edge and then roll it around the edge a bit. I turn off the power and trim the edge next. To trim the edge I use a bar of cold rolled steel with crisp corners and with a shearing action at a slight angle I shear off the excess paper. this is also a good time to wax the table
If you go with the master products disc cement, buy it in the smallest containers they sell which is quarts. I buy two at a time and get 6 changes per quart. Store the container upside down, and even so it will go bad before you can use it all up.
Robin
