Titebond III failure???
I glued two pieces of cherry together this morning with Titebond III. (Its what I had, normally use Titebond I)
The joint was freshly jointed and fit well. Carefully applied the glue and brushed it out. Had a minimal amount of squeeze out on both sides. Carefully mad sure the squeeze out was continuous. Clamped it and left it for two hours. Removed the clamps and the joint fell apart. Both sides had a sort of leathery coating of glue. This was a long grain 3/4" edge joint about 65"long.
The shop was about 75 degrees and very humid.
Any Ideas why it failed? I am suspicious of the glue. Whats the shelf life? It did appear slightly watery now that I think of it. On my way to get some fresh glue.
(One of the things that makes this a PITA is Home Depot does not stock Titebond I in pints. II and III yes, I No. I have pointed it out and asked, but they look at me like I'm the strange one.)
Re: Titebond III failure???
Lee Schierer in McKean, PA
Glue definitely has a shelf life and can also be affected by freeze thaw cycles. Check the date code on your container.
Dick Coers
+1 on shelf life
Don't get hung up on only Titebond brand. Any brand yellow glue, even white glue works just fine on interior work.
Jesse Cloud
I think they may have reformulated TBIII recently. I notice that it separates when I haven't used a bottle for a few days. First squeeze comes out really watery, then it comes out thicker than it used to. The extra thickness may require that you change the way and rate you apply the glue.
In my case, at least, I'm pretty sure there has been no freeze/thaw cycle unless it happened at Home Depot. I have found this change in the last four bottles I have bought in the last six months.
And, yep, there's nothing magic about Titebond. Next bottle I buy will probably be another brand.
III
I've had several bottle of III over the years. Every one of them needed a good shake to remix the separated contents. Actually got in the habit of doing so with all the TB's.
don stephan
You might try test glue of a couple other pair of woods to be sure it's the glue.
joe mohnike
What was the moisture content of the wood?
The wood was Cherry that has air dried for years and has been prepped and stored in the house for months. I don't know the actual percentage, but it was not "wet".
I need to go look at it again, but I think the glue had separated or settled and I did not stir or shake it. I may not. I am not interested in rescuing some dying glue.
+1on shaking
Steve jenkins
III really should be well shaken before use
