cutting melanine
AZ in Colorado Springs
A friend asked me to reduce the height of one of his kitchen cabinets, as he recently got a new (taller) refrigerator. The cabinet is made of melanine. How to cut this without chipping out? Thanks
cutting melanine
Re: cutting melanine
Ruler2112
Put the hidden side down if possible and cover the line of the cut on both sides with masking tape.
Pre-score
the cut line with a utility knife and straight edge after you tape.
Re: Pre-score
Mark and Ruler have good ideas.
The answer also depends on what tool you are using. Cut with the "teeth" cutting into the show side.
A Jigsaw cuts on the up stroke, so cut from the back.
Same for a portable circular saw.
With a router use a spiral down cut bit to cut from the show side.
Use sharp cutters.
Be gentle removing the tape.
don stephan
. . . and expect some chipping. You are trying to reduce the amount of chipping - I don't consider zero chipping a realistic goal.
John McGaw
'Real' saws made for commercial processing of melamine-coated particle board have a small scoring blade in front of the real blade and they use specially-ground blades for both purposes. I doubt that (m)any of us have such in our shops.
I've gone down the road of taping an knifing and other such techniques with varying results. My best and most reliable results have been using a blade made for the purpose, I think mine is a Jesada which tells you how old it is, and I usually make my cuts in two passes: the first with the blade up just enough to score through the coating and the second going all the way through. With even feed speed and luck I get clean cuts on both surfaces. I have tried it with a scoring cut on both faces but unless I'm using the rip fence I seem to be unable to get everything registered perfectly.
Use a router
Mark Hennebury
You will get the best chip-free cut with a solid carbide compression bit.
A compression bit has both up-cut and down-cut spirals.
The up-cut portion is at the bottom (tip end) the down-cut is at the top ( shank End)
This way it pulls up from the tip end and pushes down from the shank end giving the best clean chip-free cut to both surfaces
Walt
I've done what John has done. Two passes, the first just cutting the melamine coating. I was concerned about a 'step' between the passes but nope, they were clean no-chip cuts. The proper blade may make the two pass technique unnecessary.
I used blue painter's tape and a table saw. It worked perfectly. Thanks for all the suggestions.
