Veritas - Innovation in Tools
Tinting pre-catalyzed lacquer
AZ in Colorado Springs
I'm wondering if I can successfully tint Sherwin-Williams pre-cat lacquer using powdered milk paint.
I built a dining table for a friend and painted the base oyster white using old fashioned milk paint brand powder, covered with satin wiping poly.
They've since asked me to refinish the chairs to match (i.e., paint them) and in the intervening time I've started spraying pre-cat lacquer as the finish. So, if I can tint the lacquer with milk paint I might be able to reduce the number of required steps and get the right color.
But, will it work?
Re: Tinting pre-catalyzed lacquer
Maybebut
while using the lacquer film as the "carrier" for the pigment may work, I suspect that you'll get a rather weak film coating and thus compromise durability which would be a special concern on chairs that have a lot of wear surfaces.
Think you'd be better off repeating your prior finish routine if you want to match colors.
How would you apply it?
Dick Coers
The viscosity would be greatly increased when adding the powder. I'd say you should paint the chairs then top coat to have a chance. But no idea how the pre cat would bite into the milk paint. Might just lift it off the wood. Definitely need for experiments on scrap!!!!!
I doubt it....
John in NM
The water mixed with milk paint is kind of important, unless you are using a waterborne finish, I think you will have to keep it a two step process.
General Finishes sells a paint that performs like milk paint. I prefer it to the annoying properties of milk paint which doesn't disperse in water very well, never mind a solvent based system. (Milk paint will probably destroy the catalyst too, BTW) The problem will be getting the GF paint, or anything else, to adhere to the urethane. I think you are looking at stripping the urethane.
Woodcraft
is pushing a new line of "furniture paint" that might have some use in this situation. Could be worth a call to the company as to compatibility of top coatings as well as a custom color to match
howard gorman
Tinting precat will not give the same look as first painting with the milk paint. I've worked with milk paint a few times and there will be the different between a brushed look and a sprayed look. You could brush the milk pain on and then spray as a topcoat which I think is compatible, but check with the manufacturer. Precat is usually tinted with NGR stains, aniline dyes or universal tints. If you are going to tint the lacquer I would try to get one that best matches the paint.
TomD
Since they aren't after the Pre-cat perse, what about shooting something like latex. There is usually some cut that looks pretty close to milk paint. You might be able to pre-cat over that, but I haven't tried that, shoot samples and test whatever you do.
Old Rule?
"Latex over oil = fine; Oil over latex = fail"
Rule may have changed since last I looked.
Re: Old Rule?
Does pre-cat lacquer fall into the category of oil? My son painted a kitchen table with latex paint (!) and we sprayed several coats of pre-cat lacquer over the late. It's held up well for a family of five for a year and a half so far.
Thanks everyone ...
... for the replies. I thought this might fall onto the "too good to be true" pile. I have the paint and the lacquer of hand, so I was looking to save some steps in the application. At this point I'm not looking to innovate the overall process, but thanks for the great advice.
Old Rule
Don't know, hence the "?". If it's holding over this much time, you're good. I would guess it depends on both products and how they are applied.
Re: Old Rule?
Dick Coers
I'm shocked that the latex did not lift from the lacquer thinner. Was it something like an acrylic enamel paint? And it was solvent based pre cat?
Re: Old Rule?
Well, the paint came from Lowe's. I don't know the specs of the paint. I doubt my son still has it a year and a half later.
The lacquer is solvent based, from Sherwin Williams.
