A jig saw with twice pipes
Robin Corell in Atascadero, CA
Lately I have been cutting a lot of 1/8" steel plate using my Bosch jig saw. It's an older model I bought in 1988 and its always been a fantastic tool, one that's made me a lot of money over the years. Using Bosch brand blades it does a great job cutting the steel and if I scribe a line it will follow it..... if I can see it. This is where my problem has been, seeing the line. The steel I use is hot rolled and has a layer of very dark mill scale which makes seeing the scribe line very much like seeing a knife line on walnut.
I would love to have one of the new saws with a built in LED light, but without stepping down in quality that would mean a $250 new Bosch or a $350 Festool Both are wonderful tools I would love to own, but unfortunately not in my budget right now.
After several Rube Goldberg ideas I finely came up with a very simple modification that I made to the base plate of my jig saw for adding an LED light. I cut two 3/4" long pieces of metal electrical conduit and welded them to the side of the base (after flashing off the zinc with a torch). The inside diameter is a bit bigger than a small LED flashlight I have but with the tubing angled lightly down the flash light stays in place just fine.
Now the astute among you will have already figured out that this will prevent me from using the forward mounting of the base which allows cutting up to a wall, as well as preventing me from tilting the base. That is very true, however I rarely do either of these types of cuts. Just to be safe I may buy a replacement base for $29 just to be able to swap in an OEM base so I can tilt it if I need to.
I realize there are probably only an handful here practiced in the black arts of welding but I have no doubt the same modification could be made just as well using JB Weld or some other type of epoxy.
Re: A jig saw with twice pipes
Re: These Will Help
Soapstone is great for marking to cut with a torch or plasma but believe it or not a jig saw is capable of much more accurate cuts. Its very much like the difference in accuracy possible when working in wood using a marking knife vs a carpenters pencil.
Thanks for the link. I have a much larger round soapstone and holder but that looks about the same size as my old drafting lead holders. I'll have to look for one next time I'm at the welding supply toy store.
How flexible are you?  *LINK*
Flexible
Keith Newton
I couldn't figure out how to send a link, but check out Amazon search for LED flexible bore light.
That looks like great light for cutting! I have a nice vs Makita jigsaw with a built-in LED light and while great for most things the light is no where near that bright. And mill scale is almost impossible to mark effectively. The soapstone makes too big a mark and not much else will show up. I have on occasion sprayed a light coat of white matte or satin paint then drew lines on that.
It sounds like you do a lot of metal work. I do too on occasion. I try to use the plasma cutter when possible but even with a good guide template it's not exactly a precision cut! If I need a more precise cut I use either the jig saw, a reciprocating saw (sawzall), portaband, or big horizontal bandsaw.
BTW, for anyone who hasn't considered welding: I couldn't believe the new horizons even a small wire welder opened up for me. I used to spend so much time figuring out how to fix things and attach things, now the options are greatly expanded (and welding is easy to learn). My little weld shop now has three kinds of welding machines plus the plasma cutter.
For marking through the mill scale I use a scribe made from a triangular file cut down to about 6" and ground to a point. It is dangerously sharp and with a couple strikes makes a nice shiny line that's about .010" wide. by keeping the edge of the blade on the mark it's actually very easy to make a cut that's incredibly accurate.
I love the simplicity and speed of MIG welding but because of all the sparks it makes I only do TIG welding in my combined wood/metal shop. It's slower but spark free.
Robin
Re: Layout die
An easy way to make fine lines on metal VERY visible is to use Layout die. This is a brush or spray on very thin dye (paint) that you can scratch leaving a very easy to see line. Machinists / tool die makers use it daily. One source is http://www.mscdirect.com/browse/tnpla/00264416?src=pla&cid=PLA-Google-PLA+-+Test&CS_003=7867724&CS_010=00264416&mkwid=[*GCLIP*]&prcid=[*GCLSRC]
Probably available locally - if you know any toolmakers might ask them where they get it.
Re: Layout die substitute
William Duffield
If you're only doing it once, there's a Q&D substitute: a Sharpie pen or Magic Marker. It also works on blade bevels for adjusting the angle of the tool rest or sharpening jig. With a little work, the marker also works for flattening plane soles, but if you've something with as much real estate as a #7 or #8 to flatten, the Dykem Blue or Dykem Red will serve you better.
Good thinking! I read in a welding book that TIG was the only type of welding you could do in a white suit and not get dirty!
I worried about that so when I built my shop I dedicated a 12'x12' room to welding and grinding. I also have the horiz bandsaw and a 20 ton press in that room, anvil, and plasma cutter. With the bandsaw, portaband, and sawzall I quit using the slow, noisy, and fire-throwing chop saw completely!
The space is limited to small projects but I put in 5' wide double steel doors leading out to a 6x16 porch where I make sparks when the weather is nice. I have the bandsaw positioned so I can roll it in front of the door and extend 20' steel stock into the drive for cutting. If I need more indoor space I move into the adjacent maintenance bays.
Not the best possible situation but it does segregate the dust and sparks! I wouldn't want to run a business here but it is perfect for farm stuff and making/fixing things.
TomD
Yeah tig is clean. Another option depending on what you have around is gas welding with an aircraft torch. I like the Tinman unit. It is very similar to tig, a lot more intuitive, and gives great results, often better than TIG, though TIG is the standard, and modern process controls make it amazingly developable. Gas is limited as to material types though but it is easy on standard and 4130 steels, and that covers a lot. Plus you can braze stuff like stainless. Plus some people are running gas off the house gas, and running the oxygen from a refurbished concentrator. No HP cylinders to house. I use propane and oxygen, and will eventually move to a concentrator.
I just got the little stick box HF sells. So far it is a great tool, even though I have a 3K unit. It would add a lot to any shop. I just used it to weld up a pedestal table for a sewing machine out of 3" column and some flat plate. A bit like a support for a grinder. I also tacked the wheels on the base, which save a ton of time, though they were too small and don't roll great, still I had them. The great thing about stick is it works out of doors. With TIG it better not burn your shop down, because it really isn't an outdoor process. With stick it could burn your shop down, but it runs great out of doors. Plus you are OK in a white suit, but chipping off the flux makes a bit of a mess of the ground
Re: Layout die
Larry, I use layout dye at the milling machine on cold rolled, aluminum, etc. But the dark mill scale through the blue layout dye was not so useful. Sometimes I'll remove the scale with a wire brush but that's a pain. I think I'll try the idea of a hardened scratch awl made from a file!
I'd rather use cold rolled for making things, of course, but I have this little "problem" of a shed full of mostly hot rolled in a variety of shapes, most in 20' lengths. :-) I bought 8000 lbs of new overstock from a big machine shop at scrap prices, years ago right before steel scrap went way up. It is great to be able to pull what I need to make something on a whim.
I got a fantastic deal on a lightly used Miller 330 A/BP if your not familiar with that model its about 4" tall 3" deep and 2" wide and weighs in at a bit over 800 lbs, I think I could probably make money on it if I just scraped out the copper wire in it.
It does both stick and TIG and came to me with 75" of stinger and ground cable which I have yet to use. I would like to pick up a couple of welding cable twist connectors so I can shorten the cables down a bit and also have a twist connector at the machine but that is very low on my to do list since I do mostly TIG welding
I do have OXY-acetlene and use that mostly for silver solder and brazing. I'll have to look into an oxygen concentrator, I had not heard of them befor you mentioned it.
