How to remove veneer tape?
I have miles of it on this prone to split veneer. Never had to remove much in the past but in this case "best way"" becomes desirable.
Dampen with water, then card scraper
Dick Coers
I will also use a belt sander after it's glued down on the substrate, 120 grit.
Re: Dampen with water, then card scraper
Brian Holcombe
Peel at a long angle.
Re: How to remove veneer tape?
Sgian Dubh
Do you mean the paper tape that you wet to activate the adhesive? If so, you can use a damp cloth to reactivate the adhesive and peel off after waiting a few minutes for the water to work.
If the stuff you're talking about is more akin to masking type tape, a hair dryer can often help - warm the tape with the dryer, and peel gently, but be wary of tearing out the grain. Slainte.
Jesse Cloud
I do what Dick does, including the sander. The sander can, of course, go too far. Works best on a sander with a frame.
But usually just a spritz of water and a scraper do the job nicely.
Definitely take the time to soften the veneers. It makes a huge difference, but it only lasts for a couple of days.
thanks for adivce. What worked.
Wetting with Q-tip, waiting, then gently pulling with the soggy Q-tip in the tape-wood interface worked.....slowly. I apparently bought tenacious tape. The adhesive penetrated into the wood pores and stuck well.
There seems to be a fundamental principal for peeling with the aid of a solvent. Works for Formica and other tape and this tape too. If the wedged shaped space between what is being pulled and the substrate is kept wet with solvent the solvent wicks into the interface and what is being pulled is pulled away more or less easily by a slow steady tug.
Scraping was surprisingly ineffective. The paper balled up on the scraper edge and scraping ceased.
The adhesive is still damp, so expect sticking
Dick Coers
Sure the scraper fowls from the damp adhesive. I keep a little piece of pine and drag the burr along the wood to clear the gunk.
