Laying up the veneer
Tools of the trade. When I learned to veneer in the Headley shop we used white glue and lots of blue tape to hold the sheets in place. So, that's what I do. They used a brush to apply glue. I find a roller quicker and it evens out the glue better.
It's in the bag, a urethane bag. Cheap as I am a urethane bag's limpness makes it preferred. Note the nice vacuum pump I scored at the lawn mower shop. Long story on that one.........
Re: Laying up the veneer
Nice pump!
John in NM
That is the smallest Welch Duo-seal if I'm not mistaken, those pull about 1000 times the vacuum needed for veneering or lamination bending, and they tend to do it pretty fast and are quiet to boot. Excellent score.
Alexander Grigoriev
For glue rollers, google "brayer". You can buy a cheap kit of 3 rollers (rubber, acrylic, rubber foam), I think it's Speedball brand. Works very well.
TomD
I normally apply with a squeegee, like business cards in plastic I don't need. The vac will level the material so long as it is wet on both surfaces it will be fine. The largest vac I did was only 200 square feet and we did it with buckets and those yellow bondo squeegees. Rollers are great because they even out a coat, but for such small jobs I don't need the waste stream.
don stephan
For applying glue when veneering, I've been using black foam roller covers for years with no complaints. I keep both 4" and 9" on hand, with both roller frames. When the vacuum is drawn in the bag, the roller over gets thrown away avoiding gallons of water for cleanup. My primary veneer adhesive is urea formaldehyde because I want to longer open time and rigid result, but I had to use a PVA type last year on a job for another person.
Joseph Mulherin
Bill, what model is that pump?
Alexander Grigoriev
Squeegee works, but a roller is faster. A rubber (non-foam) roller is easy to clean.
