Old veneer question
Old veneer question
Old veneer question
I haven't used veneer much. Someone gave me 4 pieces of old, maybe ancient, veneer. It is nice in that it is 0.032" thick, not the tissue paper available now days. But it is brittle as can be seen by the fractured ends. Hard to handle and cut. Does old veneer get this way or is this piece just unusually brittle.
As can be seen this walnut is quite dark, and highly figured. I am hoping for dramatic "blotching" when the oil and stain go on.
Re: Old veneer question
I am no expert, but there are solutions for softening veneer with glycerin. I have seen it used on veneer that is seriously wrinkled, but I don't know if it will add anything to your ancient and beautiful stuff. Google "softening Veneer....." and a bunch of stuff comes up. David Marks used it on his show, back in the day.
don stephan
Occasionally I'll come across veneer that splits easily. One work around while handling is to tape across the end on the glue side with blue masking tape, then on the show side with veneer tape. Peel off the masking tape when ready to glue. I'll often do the same with splits running with the grain to stabilize until glued. If the veneer is this fragile, nothing wrong with stabilizing both sides with tape as above where it needs to be cut.
Sgian Dubh
Yes, old veneer can become brittle, primarily through becoming overly dry I suspect. Most suppliers and workshops aim to keep their veneers at about 60% MC to reduce the chances of splits like you've got, and excessive brittleness. It can be softened up with various softening recipes. Those splits can be troublesome, but taping them together often works. Here are a few veneer softening recipes you might find help: http://www.richardjonesfurniture.com/Articles/flatten-veneer/flatten-veneer.html Slainte.
helpful suggestions
Given the vapor pressure of glycerin I would think that it would never leave the wood and interfere with glue bonding. But, it seems to part of all the recipes.
Correction
Sgian Dubh
I said,"Most suppliers and workshops aim to keep their veneers at about 60% MC"
It should have read 'in conditions of about 60% RH', not MC. Slainte.
