radius grinding wheels. *LINK*
I'm interested if anyone is using curved grinding wheels. I got a special jig from Don Geiger that creates a radiused grinding wheel. I've just barely had time to play with it and not sure how to test it just yet. Don says because you are only grinding at one point it doesn't heat up blades as bad especially chisels and plane blades because less of the blade is in contact with the wheel.
My friend Ken Rizzo that sells the CBN wheels is now selling a radiused wheel for the same reason. He says the flat wood workers really like it and wants to know how I think woodturners would like it.
Well so far just the 120 grit white aluminum oxide wheel on some turning tools I don't see any difference but then I've been sharpening tools so long I don't usually overheat them anyway. I hope to put some carbon steel plane blades to the test when I get back from Atlanta next week. Thought I'd ask if any of you guys were using a radiused wheel.
http://www.geigerssolutions.com/Tru-N-Dress-Grand-Slam.html
