project update *LINK*
Robin Corell
I just updated my build blog for the table I posted about a while back. There are actually several posts will photos of the progress to date. Please feel free to ask any questions. For some reason I am not able to post the blog location as a live link could someone please explain how I can do that for future project updates.
https://robin-corell.squarespace.com/inthestudio
Update
Re: project update *LINK*
Re: project update
AZ in Colorado Springs
The link works fine on my android phone.
Profile names
Hi Robin,
I'm not quite sure how you tried to post the live link you mentioned. It is possible to include a live link in the text of your message by using HTML code, but that's not generally a good idea unless you're confident of the syntax. The standard way to post a link is to paste it into the Optional Link URL box at the bottom of your message. To have that option you need to be signed in as a registered member, which means you need to be using the exact user name that you've registered in your profile, which in your case is "Robin Corell in Atascadero CA", not just "Robin Corell", otherwise our system doesn't know that you are a registered user, and you won't see the optional formatting and uplinking options in the message-post dialog.
Hopefully this clears things up for you. I've made your link live in the meantime and also added the link below your message through the Optional Image URL box.
Thanks Ellis
Re: project update
I'm seeing a whole lot of awesomeness there. Simplicity of form that is enriched by the textural sculpting. Rock on! Cool drill press by the way. ;-)
T.
Re: project update
Nice! I like the idea of the recessed glides too.
Re: project update
Robin Corell in Atascadero, CA
Thanks. That drill press is a delta UniDrill from 1961. Its a standard delta drill head and performs like one. it will be showing up again in my photos once I start on the metal work. I spin the head to the side and use it as my welding table.
Hows retirement?
Robin
Alan Young
How I load individual pics from a webpage
Alan Young
First I memorized a code I've know so long I can't remember learning it-
I assume I got from Ellis...
Type these symbols (including the space between the g and the s)
and voila!
Retirement?
Technically, I retired from a 27 year career. What came after is a 50+ hour a week self-employed woodworking job. It didn't take long for me to realize that I never did retire, I merely changed careers! But so far, so good. The work is harder, the hours longer, but I wouldn't trade it for the old career for a $million.
T.
