Have you tried an old coffeemaker as filter stand?
Wayland
My old coffeemaker died yesterday, and, after ascertaining that the heading element was definitely fried and incapable of being repaired, I had the thought that it could be used as a convenient filter stand for filtering varnish before use in spraying operations.
My question is whether anyone has tried this and if so, whether it worked and/or what problems there are to watch out for. My tentative plan is to break off the coffee funnel shutoff valve so the filtered varnish can run directly into the spray gun cup. I'm not sure a paper coffee filter will work; the pore opening may be too small for water based poly, and might trap the poly particles themselves. Maybe instead I can use the somewhat coarser screen that came with the machine that I never used because it allowed too much fine sediment to pass through into the coffee.
Let me know your experience, if any.
Thanks in advance.
Wayland
