Wood finish
Wood finish
Wood finish
RICK SNYDER
I'm working on a foot stool for a choir director to stand on. Is there a non skid finish that would work over stained wood?
Thanks, Rick
Re: Wood finish
Re: Non-slip
You can mix dry no-skid powder (from paint store or borg or marine supply) into your topcoat or just use grip tape made for stair treads.
Re: Wood finish
Re: Wood finish *LINK*
John in NM
We've sprinkled fine sand into wet varnish, works well as long as the varnish lasts (indoor applications it should last well).
The tape is also an excellent option and easily renewed. It would probably need a varnished surface rather than just stained - might not stick well if there is no top coat. Stuff is pretty widely available, I think even Home Depot sells it.
tape
Re: Wood finish
Re: Wood finish
I doubt you can retain the visual attractiveness of a stained wood surface with any finish containing enough sand or other "grit" that it would work as a non-skid surface. All of the non-skid coatings I have seen are solid color paint sold as deck / ramp coatings.
I agree with the previous post recommending using the non-skid adhesive strips. These should be available at the big box stores to be used in bathtubs / showers. An alternative is the strips sold in Automotive supply stores for use on Van steps. My van has black strips installed on the steps, works very well.
