Curious
John in NM
I learned to use steel wool or something like it to "cut" the raised grain off, and then not sand again afterwards. As with any technique learned from another and not experimented with, it may be incorrect - just wondering how others learned to raise the grain.
Grain raising is something I never used to do until I used a few water based finishes - then it clearly became a necessary step for some woods. Honestly, I tend to avoid water based finish as a result.
I do raise the grain after any rasp work. Amazing how even after sanding all the rasp marks out, they can pop right back up given a little water. In that case I do sand afterwards, because it's really a different kind of grain raising - taking out dents made by the rasp teeth more so than fibers folded over into the wood pores by sanding.
