Hardware Rec
Hardware Rec
Hardware Rec
Building one of these for my DIL and son
As you can see, the seat has two lift-up lids for storage mounted with piano hinge.
Given that they have two kids under 5, I'm planning on putting in soft closers that also limit how far back the lids will open so the back slats don't get beaten up and small fingers don't get slammed on the closing. For anyone who has used these things a few questions
a) brand/model recommendation?
b) one or two per lid?
c) alternatives?
Re: Hardware Rec
Re: Hardware Rec
Keith Newton
Mark, The only ones I've used were about 25 year ago. They were from Hafele, and I think they had a way to set the resistance, to compensate for the weight of the door. I could set them where they would hold the lids open, then with a light touch, would descend slowly.
Sorry I don't have a part number for you. I haven't bought from them in a very long time.
Re: Hardware Rec
Re: Hardware Rec
Hands down, I'd recommend the ones that Rockler sells. The lid is just stationary. You open and close it gently. It never slams, and I think it opens just over 90º.
I last bought these about 17 years ago, so I don't even know if they still sell them.
Re: Hardware Rec
Re: Hardware Rec
AZ in Colorado Springs
If you are thinking of torsion hinges, Rockler does sell them, in varying strength from 15 to 60 pounds and maybe more. They have an online calculator to determine what strength you need. You have to weigh the lid and know its width (front to back). I teach woodworking at the AF Academy and they're popular for chests that will be used as toy boxes.
Re: Hardware Rec
Re: Hardware Rec
The torsion hinges I looked up are a lot slicker-looking than the ones I was talking about, but the key ingredient is some kind of spring arrangement --whether torsion or compression -- that counterbalances the weight of the lid. Our major advertisers, Woodcraft and Lee Valley Tools, both sell the compression-hinge variety I'm familiar with. As you said, you need to calculate the inch-lb rating of the hinge based on the depth oc the lid and its weight. Thanks for the tip on those torsion hinges.
Re: Hardware Rec
Rocklers
Thanks AZ.
I looked at Rockler's supports but see a problem in that, as shown, they open to 105° which will allow the seat to hit the back. That's about 10° too much for my application. Do you know if there's an adjustment or can they be "misplaced" in mounting to change the open position without messing up the action?
m
Re: Hardware Rec
Re: Rocklers
No, there's no provision for any adjustment. The only way to alter the range of movement would be to build a sloped mounting point. But the hinges go into a mortician on the back of your seat and screws go both vertically and horizontally. And if you "sloped" the hinge, the back of it, along with the barrel, would rise up. Not adaptable to your beautiful seat. But they are great for other applications.
Re: Hardware Rec
A beautiful piece but, for my taste
Gary Smyth
with a flat hard seat it cries for a seat cushion for any use/comfort. Something about three inches in thickness and perhaps tufted. I understand that it may alter the all wood appearance then, but certainly more helpful for the human bottom. One possible advantage is if a fitted cushion is in the offing, kids will be less likely to lift the lid unsupervised. The splats may or may not need additional length if the suggestion is considered.
Re: Hardware Rec
Perhaps
in the future some cushions might be added, but for now, "short" legs won't serve to put small butts on a higher seat surface. ;)
The bench is for their entry. I'll be coating the inside of the seat boxes with epoxy to make them water and mud proof for the shoes that are sure to be dumped in there "as is" (or "are")
Re: Hardware Rec
Re: Hardware Rec
DGW
I built my new born nephew a Winnie the Pooh toybox about 10 years ago. I used two box lid supports sold by Rockler. Never had a problem with broken noggins or fingers.
You can see the ToyBox here. http://walkerwoodworking.stewartmg.com/photos.html
The Rockler Box lid supports are here:
http://www.rockler.com/box-lid-supports-right-mount
I bought a left and right lid support.
Re: Hardware Rec
Re: Hardware Rec
DGW
By the way. The Rockler Lid Supports allow a lid to open to 85 degrees so it will protect your back slats too.
Re: Hardware Rec
Thanks DG
Have talked to the Rockler support guy and he recommended the same ones.
Re: Hardware Rec
Re: Thanks DG
William Duffield
Woodcraft (and I suspect Rockler, too) offer them in three different strengths, so you can choose exactly what you need for six different lid weights.
Re: Hardware Rec
Did the Calc
Lids need 44 i/lb so 1 closer will work for each.
Going with the spring loaded 85° unit rather than the gas-operated 105° version.
