Re: Micrologging, milling, and stickering
Grant in Iowa
Keith,
The winch was admittedly a splurge. We could have gotten a farm store cheapie, but I have had them fail before, we decided to buy one more that would stand a chance of outliving me. We also wanted 3/8" cable that would provide some overkill, as well as be more kink free. So, I bought a Warn Zeon 10 with the multi-mount option. The multi-mount is a carrier, which is designed to mate in to a Category III hitch receiver. This arrangement allows me a great deal of flexibility, as well as being able to remove and store the winch when not needed.
So the trailer has a receiver mounted to the frame at the front of the trailer, and the winch slides in to that. The winch slides in, a pin is put in place, and the power hooked up to the on board trailer battery. The battery has more than enough juice to run the winch for a load of logs. I can actually also use the winch in the same location to unload the logs. I will have to provide photos to clarify this arrangement a bit perhaps. Basically, the winch cable end hooks to a stake pocket at the rear of the trailer on one side, runs forward and around the front of a log, and is routed to back to the rear of the trailer on the opposite side, through a snatch block and then to the winch. Tightening the winch forces the log off the trailer. I usually find, however, that I can tie the log to a fence post or second vehicle to remove logs easier, so I have not used the method much.
I also mounted a receiver on the front of my truck, added a second battery in the truck factory location made for that, and wired it all up with a battery isolator. The winch can be moved between locations, although at 120 lbs, it is best to have two people to move it around. I also use a locking pin when leaving the winch on the trailer to guard against theft. I tend to store the winch when not in use.
My sawyer is not a full time sawyer, but mills nearly every weekend and some evenings here and there in summer. I have known him for a dozen years. He generally charges people 30 cents per board foot for milling, but he expects they will off bear the lumber and slabs at that rate. He does offer me a bit of a discount from that rate that I have promised not to disclose. As I have said he likes that I bring help and know my role while the milling is happening. He also likes the fact that I can deliver clean logs that haven't been dragged, thanks to the log arch.
He is also willing to work by the hour, but I don't know the rate for that service. He usually works by the hour for odd custom jobs or jobs with very small logs. he had a guy drop off a bunch of cherry logs that were 12" max recently. I think that guy got the hourly rate.
I think he gets $1.50 per mile one way for a travel fee for plus the normal rate for mobile jobs. I haven't used that option in about 8 years.
Here in Iowa, I have heard two sawyers tell me that milling is not taxed if it is done on a farm and the logs came from a farm. They call it a farm product if it meets that test. Tax laws vary I suppose, but I haven't paid sales tax. I know Iowa is very pro farmer with the laws.
Keith, you mention a swinging arch arrangement on your trailer to load logs. I am intrigued and would like to see a photo or drawing of how it works. I actually changed from a typical car trailer to my tilt bed car trailer for easier log loading and unloading. It kind of sounds like you might have solved the problem with an arch.
Truth be known, I too will often go straight to the trailer with a log when possible. I will back the trailer up next to the log so just the front of the log will roll on to the tilted trailer. Then, I get behind the log with my tractor and push it aboard. Even though the bucket lift capacity is about 600 lbs, this is usually enough with smaller logs, and the tractor can easily slide a log lengthwise on the wooden deck of the trailer. I do try to avoid hauling the log arch and tractor to a location, unless the job requires it.
I have found that most semi-urban land owners will give you a log if you can move it without tearing up their property. That has been my niche, and I have not paid for a log to date. I do usually offer to clean things up, which is indeed work. I will refer you to my photo and say that I could use the exercise anyway
Thanks for the conversation.
Grant in Iowa
