Packaging Furniture for Shipping
don stephan
In a few days I hope to box up a small side table to ship from Cincinnati to Duluth Minn. I've heard more than once that bubble wrap will mark some finishes, perhaps due to chemical(s) in the plastic film. Will a single layer of brown Kraft wrapping paper protect against this?
The top and base are approx. 15" diameter octagons, which is additional challenge. My thought is to line a larger box with 2" blue or pink insulating Styrofoam, wrap the table well with the wrapping paper, and then . . .
Tightly pack the space with peanuts? Bags of air, if I can find a source? Would you place a layer of bubble wrap inside the hard Styrofoam first (if bubble wrap won't mark the finish)?
Has anyone packed furniture in cardboard box for UPS shipment?
Thanks in advance.
Re: Packaging Furniture for Shipping
Yonak
don, you didn't say what finish was used but, honestly, I wouldn't trust putting anything against a new finish. Have you thought about screwing the table to a platform and reinforcing the corners of the box with sticks ? ..Maybe also figure a way to stiffen the cardboard against punctures, as well, or instead of the sticks.
If you do decide to cushion directly against the table, you might put the table in a nice slippery plastic bag (such as polypropylene). Don't put polystyrene, or any paper product directly against the finish, if it's vulnerable.
AZ in Colorado Springs
I don't see the octogon as an issue -- just build a square crate. Maybe wrap the piece in some furniture pads then assemble the crate around it. Yes, two crates. Check with the carrier for weight and cube limitations.
whoops,  only one table
Dick Coers
Nothing sends fear through me more than shipping furniture. Bubble wrap can mark lacquer, I've seen it on someone else's furniture and had to rub it out. Kraft paper is also abrasive. Do you have a Harbor Freight near you? They sell shipping blankets really cheaply. If not a cheap bed blanket will work. After that, you can't build the envelope around it strong enough. Definitely double what you think will work. My friend uses a white glove service to ship his furniture now. It seemed very reasonable the last time he shipped from Peoria to Manhattan, NY. It is a husband and wife team in a huge Mercedes van. You don't have to even box it if you don't want. They shipping blanket wrap it and strap it to the side of the van. I'll get the contact info if you want.
don stephan
Thanks everyone, especially for the reminder that kraft paper is a mild abrasive. Maybe a layer of muslin under the kraft paper.
The pedestal base is assembled with two carriage bolts. Think it will be easier (on my end) to package all the individual pieces with assembly instructions for my brother at the other end.
Robin Corell
I use Tyvek to protect the finish on furniture or artwork that I crate. It is is non abrasive and archival to the point that museums are using the stuff. Its also available without the printing that typical house wrap has.
I hate peanuts
Gary Smyth
They are a pain and with any objet of weight they tend to move out of the way when the package is placed on its side or upside down in the truck or on a conveyor belt somewhere. With peanuts almost always I find the object sent on one side or another in the package. Give the furniture a cushioned buffer between the furniture and the box I find newspapers crumpled a much better packing material than peanuts.
