Miter Saws
Miter Saws
Miter Saws
David Frame
Hi Everyone,
I'm looking for a new miter saw. The plastic on my 20+ year old Hitachi C10FS is literally falling apart. The saw itself is good. It just needs new plastic coverings. Most of the parts needed are not available. If anyone knows where I can get parts for it, please contact me through this message.
Does anyone know how well the Makita LS1018 performs? This saw is within my price range. I would be grateful for any information.
Thanks for your time,
David
Re: Miter Saws
Can't go wrong
We tested miter saws several times, and Makita always came out on top. I have the 12" version of that saw and it's great.
Re: Miter Saws
Uh oh!
Tony - Memphis
Hate to hear that....I have the same saw! So far, so good....
Re: Miter Saws
Nuthin' But Good
I have the LS 12-11 but have several friends, one a contractor, who bought the 1018. Every one of them is pleased with the saw's performance and accuracy.
My saw had a real issue with slightly wavy cut lines. Turned out it was due to the thin kerf blade that came with the saw and just wasn't stiff enough to cut hard woods. Full kerf blade solved the issue.
Re: Miter Saws
Re: Can't go wrong
David Frame
Hi Ellis,
Thanks for your assurance in Makita. This saw is sensibly priced. I have other Makita tools and none of them have yet to let me down.
My wife wants to give me a fathers day present I can put to use. You know what that means don't you? More remodeling around the house. I don't mind, but it's hard to make a buck and work on my home at the same time.
Thanks for your confidence and time,
David
P.S.
I'll order today.
Re: Miter Saws
Re: Can't go wrong
John C Lucas
I looked at all the saws 2 years ago including Festool which is the one i really wanted. After much research i bought the makita sliding miter saw. An excellent tool. With a good blade it does precision work. With the blade it came with it does excellent work
Re: Miter Saws
Re: Miter Saws
Grant in Iowa
I have the LS-1012 which was purchased about 8 years ago. No trouble whatsoever, and it even came with a nice blade. To be able to have a spare, I purchased a Freud 100 tooth 12" blade once the original needed to be sharpened. I love the Freud blade, glass smooth cuts, and the original blade also performs quite well for a stock blade.
I have a background working in a machine shop, so I try to align my machines as well as possible for best results. The Makita allows each adjustment to be made.
Dust collection isn't the best, but then it is marginal on every saw of this type. I built a hood that makes it adequate. I could provide an image if you like.
I would buy my 8 year old saw again, even without the improvements I'm sure they made since then.
Most will say there is no substitute for tablesaw cuts, but i have found my saw as aligned comes about as close as I could ever expect to that of a Unisaw. Well within the tolerances of woodwork.
FWIW,
Grant in Iowa
Re: Miter Saws
Re: Can't go wrong
William Duffield
The Festool Kapex is most probably a lot more saw than most of us need, or are willing to pay for. It does have (among others) one advantage that most people miss, but that can be very important (or, OTOH, totally meaningless). The distance between the fence and the back wall is significantly less than any other SCMS, even the Bosch with the hinges. Since people often build very long tables for their chopsaw, this can make a big difference in a cramped shop.
Re: Miter Saws
Re: Miter Saws
David Frame
Hi Grant,
I'm probably with the "Most People" as far as my Unisaw is concerned. I bought it over 28 years ago and it continues me serve well. The paint job on my saw needs renewing, but as long as I keep the trunnions, teeth, and worm screws clean and dry lubricated, my saw works as if it were new. From the time I bought it to now, there is no slop in this particular saw.
Now about saw blades. I've used just about every blade on the market. If I want longevity, I use Amana, for sharpness, Forrest, and for all around 50 tooth Freud. The most important element of my Unisaw, is it will do so much.
I knew more about table saws at 15 yrs, old, than most learn in a lifetime. I worked in a shop that fabricated solid wood and paneled interiors, passenger seating, pilot chairs, booths, tables and cabinets for work boats push boats, crew boats, tug boats and ferries. I took over that shop at 16. The gentleman that taught me what I knew at that time had cancer and I'll be forever grateful for his knowledge. It started me on a path that was already in me.
My father, David L. Frame of The David Frame Shop in Doylestown PA., was an artist of whom I did not know. My mother would see my drawings and paintings and say to me," Your just like your father." My technical side came from my mother. She was an accountant for Blue Cross as it was called in the 60's. I met my dad at 26 and other than our beliefs, we were like one person. Both of us were looking for something different in life. Now that he has passed, I look alone.
Saying all that though, doesn't relieve me of the long crosscuts, bevels, and miters I need to make a lot of the time. I never really liked radial arm saws maybe because I never used a good one. My Hitachi C10FS was my first slide compound miter saw. It served me well for about 20 years. The only part I never liked on it were it's stops. They do not lock in place. Everything is still good on this saw except for the surrounding plastic. It is literally falling apart. I can't have my employees getting electrocuted or loose a finger in the belt drive, which is now open. That is why I asked for ya'lls help in choosing a new miter saw. I bought the Makita LS1018. I'm sure it will be fine.
Thanks for everyone's help,
David L. Frame Jr.
